Old 02-05-2008, 09:47 AM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question 6 Lug Disc Brake Conversion Question!!!
okay guys, here's the story. Got my 6 lug, disc brake conversion from GMCPauls, thanks Amber! Got a proportioning valve from CPP. Good there too.
Now it comes to plumbing the proportioning valve. It appears as if I will have to run a line from each front brake to separate inlets into the proportioning valve. (My '69 only had one outlet for the front and one for th rear).
Okay, the lines run from each front brake caliper to a central tee at the frame and then ONE line goes up to the proportioning valve.
Now, am I going to have to remove the tee and run 2 separate lines to the prop valve? Will I need to get brake lines bent for a '71 - '72??
thanks gang!!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-05-2008, 10:38 AM   #2
71 super
71 super's Avatar
Re: 6 Lug Disc Brake Conversion Question!!!
Can you show a picture of the prop valve you have? It should have 1 line from front of M/C to valve and one line from back of m/c to the prop valve. These should travel down the frame and tee to the front lines and hoses and the rear line should follow the crossmember have a union near starter and travel to the rear of the truck. The 71-72 lines are very similar to the earlier models in routing , and there are NOT two lines coming from the front brakes to the prop valve, only one.
71 super is offline   Reply With Quote
Old 02-05-2008, 10:47 AM   #3
tcb-1
tcb-1's Avatar
here's the instruction sheet:
http://www.classicperform.com/Instructions/PDF/PVK.pdf
Doug
Old 02-05-2008, 11:29 AM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
"In some cases, the right front line will be
plugged off at the proportioning valve and the left front line
will go to a “T” fitting. From the “T” fitting, the front lines
then split off and go to the left and right wheels. "
Your question is answered right there!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 02-05-2008, 11:34 AM   #5
tcb-1
tcb-1's Avatar
OMG..... I only read instructions when I don't know what's going on. I think I should start reading post haste.....
I am a dork.
Thanks Riveted, I'm glad your there for me!
Doug
Old 02-05-2008, 11:39 AM   #6
Riveted1
Tasty Cakes!
Riveted1's Avatar
No problem, I'm definitely guilty of the same thing.... Sometimes it helps to have another perspective
Let us know how the install goes!
