View Poll Results: Column Shifter or Floor Shifter?
Column Shifter 17 65.38%
Megashifter 9 34.62%
Voters: 26. You may not vote on this poll
Old 02-05-2008, 01:07 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Column Shift or Floor Shift?
I'm getting ready to drop an auto (700r4) in my truck and wanted to get some input on what route I should go with the shifter; column shifter off of a donor truck or a B&M Truck Megashifter... Originally, I was gonna go with the Megashifter since I've already got a hole cut in my floor but I can actually pickup a column shifter at a decent price. So what do you all think?
Ole Blue 68 is offline   Reply With Quote
Old 02-05-2008, 01:23 PM   #2
Ron 586
RIP Mr Ron
Ron 586's Avatar
Re: Column Shift or Floor Shift?
If it's going to be mostly a driver put it on the column. If you are going to race it then get the floor mounted model. Really just buy the one you want, either will do both jobs with ease.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 02-05-2008, 11:01 PM   #3
jd4300fel
jd4300fel's Avatar
I am put a floor shifter in mine mr gasket brand. my truck is on a 86 frame it made life easier dealing with the linkage going with the floor shift
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 02-05-2008, 11:28 PM   #4
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Automatic.....No Question. Go with the Column Shifter.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 02-05-2008, 11:33 PM   #5
shelby987
shelby987's Avatar
Lol, I thought this was regarding a manual trans......either way, for these truck, column is the way to go.....keeps the bench seat pratical.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 02-05-2008, 11:35 PM   #6
greasy68
greasy68's Avatar
Column shift for sure. Save the floor shifter for a big block and turbo 400.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 02-06-2008, 12:23 AM   #7
Ole Blue 68
Yeah sorry, should have made that more clear in the title. Currently, I have a 3spd manual that a PO moved from the column to the floor. Now that move makes sense to me but I wasn't so sure about what to do with an auto. Originally, I was thinking about just going with the megashifter since I've already got a hole in the floor but after talking to another guy who did the swap, he had me thinking column shift.
I've never used a megashifter before so how hard is it? This will primarily be a driver so I'd mostly be using Park, Reverse and Drive. Is that doable with a ratchet or do you have to manually go through the gears to get to Drive?
Thanks!
Old 02-06-2008, 12:37 AM   #8
Psycho71
Psycho71's Avatar
If it's just going to be a driver, go with the column shift. The mega shifters do require lifting the release lever to get from park to any gear, and again coming out of forward gear into park or reverse. You might find that a PITA while toodling around town.
I built a console for my truck, and installed the B&M Hammer shifter in mine. It has the same shifting characteristics as the mega, and I can see not liking the release lever for driving around town. But I also plan on doing some darg racing with it at some point, so the reverse lockout, and ratchet shift capabilities will be useful there. Plus, it just looks cool in the console, to me anyway.
It really all boils down to what YOU want. It's your truck.
But if you've never used a mega shifter, or one like it, it can be interesting at first. Somtimes downright odd. But it soon becomes habit. I've used several of them in past vehicles.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 02-06-2008, 01:18 AM   #9
haysonj
haysonj's Avatar
How hard is it to lift a lever not a lot differant than pushing a clutch in. It is cable operated so you could mount it on the dash if you want or roof
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-06-2008, 01:47 AM   #10
Ole Blue 68
Point well taken! I guess another consideration is my wife. She can't drive the truck at all right now because of the 3 spd. In some ways that's a good thing but it also results in her btching a lot about "that damn truck." I figure she'll btch less about it if she can actually drive it.
Also, is that the truck megashifter in your cab? Is that stock height or did you modify it?
Old 02-06-2008, 02:08 AM   #11
haysonj
haysonj's Avatar
Thats the truck one and it comes with a plastic housing the you have to cut to match your floor pan. Pretty simple really
Old 02-06-2008, 02:08 AM   #12
Brad
Out of the carpool lane.
Brad's Avatar
I'm also facing the same dillema right now. I don't like column shifters, but I like the ugly bulkiness of the auto floor shifters even less. I also think the Lokar shifters with their long handles look goofy. I'll be going with the column shifter.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-06-2008, 02:09 AM   #13
Ole Blue 68
Cool, that actually comes up higher than I thought it did. Looks good!
Old 02-06-2008, 04:31 AM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Column shifter...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-06-2008, 05:05 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
Is this too bulky?
I prefer floor shift. Especially with a 700R4. They like to shift into OD too early. It's nice to be able to tap it back and forth between 3rd and 4th using a floor shift than using a column.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-06-2008, 07:00 AM   #16
Frizzle Fry
Frizzle Fry's Avatar
Columns are cool. I used to think the opposite but I guess I've graduated... or regressed
Frizzle Fry is offline   Reply With Quote
