Old 01-29-2008, 04:43 AM   #1
truckn'
truckn''s Avatar
dropping my 65 gmc
what is the cheapest way to drop my truck without Jerry rigging. I want it lower but want it to be right.?
truckn' is offline   Reply With Quote
Old 01-29-2008, 08:59 AM   #2
1966gmc
Why does it taste purple?
1966gmc's Avatar
Re: dropping my 65 gmc
Cheap and safe usually don't go together.Front coils and drop spindles and rear drop leafs are the way to go and the way I will be goin when I do it.
You could cut the front springs and take a few leafs out if you wanted to though
1966gmc is offline   Reply With Quote
Old 02-01-2008, 06:49 AM   #3
slug
slug's Avatar
I Thought The Old 65's Had Coil Spring Rears In Them
slug is offline   Reply With Quote
Old 02-01-2008, 07:45 AM   #4
SCOTI
SCOTI's Avatar
Depends on how it was optioned. IIRC, GMC were leaf w/coils optional & Chevys were coil w/leafs (leaves?) optional.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2008, 02:30 PM   #5
Dinos63
chevy only
Dinos63's Avatar
How low are you thinking? and tire combo
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-05-2008, 04:51 AM   #6
truckn'
truckn''s Avatar
probably a 2/4 if that sounds right. still green behind ears. not sure about tire combo. I like nice thick tires instead of low profiles.
Old 02-05-2008, 05:30 AM   #7
SCOTI
SCOTI's Avatar
Leaf or coil spring rear suspension?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2008, 11:09 AM   #8
truckn'
truckn''s Avatar
leaf springs in the rear
Old 02-07-2008, 02:01 PM   #9
SCOTI
SCOTI's Avatar
Flip kit nets more 'useful' drop per dollar. Dropped leafs tend to lose cargo capacity while a flip kit maintains the same capacity as long as adequate clearance is there for axle travel.
Dropped springs up front is the simplest route until you want disc brakes, then go drop spindles.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2008, 10:13 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Contact ECE (Early Classic Enterprises), they will hook you up!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
