02-09-2008, 11:17 AM | #1 |
whats the good & bad of useing a 700r4 in a 72swb?
can anyone tell me the good or bad of useing a 84 camaro 700r4 in these old trucks. or is it better to stay with a 350 or 400. thanks bill
i have 67/72 chevy truck parts f/s. |
02-09-2008, 11:23 AM | #2 |
Re: whats the good & bad of useing a 700r4 in a 72swb?
if it was up to me i'd run one in my daily driver.
I got my gmc and it had a 700r4 in it and dumb me gave it back to the guy and put my 350 in it instead. O/D would be nice for driving down the highway
72 LWB |
02-09-2008, 12:03 PM | #3 |
The only thing bad is the year of the trans, I think up to 85 they had issues that were resolved in the later trans.
Check this link, lots of good stuff here. http://www.geocities.com/crosley_az/700id.htm
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 02-09-2008 at 12:09 PM. |
02-09-2008, 12:31 PM | #4 |
Weekend Warrior
I put one in a '69 Step side behind a 305 and I think a 3.73 rear (originally a 6cly 4speed). You have to make sure that the TV Cable is set right, or you will burn the tranny up very quickly. www.bowtieoverdrives.com sells kits to hook up the TV cable to whatever carb you have, and they have the "lock-up" kit for the converter. If you don't have the converter lock up, then it will constantly slip like a stall speed when in overdrive - causing excessive heat and wear.
when they are set up right they are great on the highway. Not really great for towing in OD. Have a tall first gear to get you off the line. I loved it - would do 80 and purr. It was pretty good on gas too, maybe about 15mpg or a bit higher. Not too bad for driving a brick wall.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 02-09-2008 at 12:32 PM. |
02-09-2008, 12:53 PM | #5 |
I had one custom built that is now in LowBuck with better clutch disks, re-worked oil psi system and a fully auto lock up in the end of third and all of fourth. I am running a 2300 stall, 3.41 R&P and a 92 vett LT1. I have towed my 16' car trailer with my wife's 63 SWB GMC in it with no problem. 75mph at 2100 rpm is great on the freeway and first gear is just plain fun!
Kevin LFD Inc. |
02-09-2008, 08:48 PM | #6 |
The earlier 700's were not desirable tranny's....best to get one made after 1986 or better yet, a custom built unit. If built right [and I really stress this one] they can be great.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
02-09-2008, 10:59 PM | #7 |
I run a 700R4 and love it. But, Do your homework on the TV cable set up or you will have a paper weight. I speak from experience. I would suggest you get a good built unit and have someone set up the TV for you if you are not familiar. You will love the OD, 1st gear and drivability.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
02-09-2008, 11:12 PM | #8 |
Rottenwood Garage Member
later ones are better.......but 700 is still a great choice!!!!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
02-09-2008, 11:21 PM | #9 |
I'M TRUCK CRAZY!
I wish I had a 700
02-10-2008, 12:42 AM | #10 |
87 and older are great for scrap. get a 87-91 built well and you will be oky.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-10-2008, 12:50 AM | #11 |
Senior Moment
How well do they hold up under lots of Torque and say 500 HP??
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
02-10-2008, 01:33 AM | #12 |
I had a 700R4 on the back of a ZZ3 Crate motor and it was a great combo. As I recall, I had to move the trans cross member back and have the drive shaft shortened (also replaced u-joints and carrier bearing at the same time as a precaution). I used the stock column shifter and didn't worry about my inability to manually shift into Low.
Good Luck! |
02-10-2008, 01:50 AM | #13 |
I put one in my truck out of an 83 bird. It lasted 5K. I didn't have the cable set right. Bought a rebuilt one and installed a BO TV kit and lock up kit. I love it. With a 3.73 I turn about 2300 rpm at 75/80 mph. I did spend a good bit of money on the rebuild and the kits, but I've already put about 8K on the truck since last November. If you don't drive it a lot a 3.08 rear end with a Th350 or 400 would get you less, but similar fuel mileage to a 700R4/3.73.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-10-2008, 01:52 AM | #14 |
Unless you have it specifically built for that kind of power, I'd give a stock 700R4 about a week of abuse before it blows
02-10-2008, 02:05 AM | #15 |
Bill,
Have you look into using your stock trans and a gear vendors unit? The gear vendors is $$$, but there is an advantage to splitting gears while towing. |
02-10-2008, 01:52 PM | #16 |
i am building my truck for playing only no work. and the reason i ask the ? is i have a 400 and 3 -350's and just bought a 305 & 700 r4 out of my sons 84 camaro last nite. i was wanting to go with the best out of them all. i think the 350 or 400 will work better for me & less mod's. thanks for all the help & info. this is a great board.
02-10-2008, 02:19 PM | #17 |
Never had any luck with them or any metric to be honest. Ive had a few rebuilt without the best luck either. I think they would be ok if you spend the money to have them all beefed up but a stock rebuild wont take a lot. Im a 350-400 fan, both are good in my book...
02-10-2008, 02:48 PM | #18 | |
Kevin LFD Inc. Last edited by Rokcrln; 02-10-2008 at 02:49 PM. |
02-10-2008, 03:09 PM | #19 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-10-2008, 03:38 PM | #20 |
Long Fleet Club
Here is the solution for the TV cable. They also have one for the '82 - '86
TCI® TCI® Automotive
151 Industrial Dr. * Ashland, MS 38603 Phone: 1-888-776-9824 * Fax: (662) 224-8255 www.tciauto.com Constant Pressure Valve Body™ Now Available For 1987-92 GM 700R4 Transmissions Latest TCI® Constant Pressure Valve Body™ for GM 1987-92 700R4 eliminates low line pressure condition and ensures perfect transmission operation Guarantee proper performance with your 1987-92 GM 700R4 automatic transmission by installing a new TCI® Constant Pressure Valve Body™. Many street performance enthusiasts incorrectly install the critical TV cable that is used to set internal line pressure and part throttle shifting by either leaving it disconnected or improperly adjusted. The result – less then optimum line pressure that results in clutch and band slippage and ultimately, transmission failure. Until recently, the TV cable adjustment on GM 700R4 transmissions often required an experienced mechanic. Compatible with stock and aftermarket transmissions, installation of the TCI® 700R4 Constant Pressure Valve Body™ avoids common transmission destruction by maintaining adequate line pressure at all times. While the TV cable still needs connection for proper transmission operation, the TCI® 700R4 Constant Pressure Valve Body™ provides more liberty when setting part throttle shift points and works with a variety of cable brackets and carburetor applications. For more information about the TCI® 700R4 Constant Pressure Valve Body™ or any other TCI® product, call us at 1-888-776-9824, or visit us online at www.tciauto.com. Quick Summary Product: TCI® 1987-92 GM 700R4 Constant Pressure Valve Body™ Part Number: #376020 Features & Benefits: • 1987-92 GM 700R4 Constant Pressure Valve Body™ eliminates low line pressure due to improper TV cable adjustment • Street & mild race applications • Still maintains part throttle shift points with TV cable adjustment • Works with wide variety of throttle brackets and carburetion systems • Compatible with stock and aftermarket transmissions; installation instructions included
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
