Old 02-10-2008, 01:09 AM   #1
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Sway bar installation question..
I think I already know the answer to this but I thought I'd ask anyway.
When installing the frame brackets on a truck that didn't org. come with a sway bar, do I need to grind out the rivets at the bottom of the front cross member to bolt the support brackets to?
Seems like thats where it needs to go.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 02-10-2008, 01:40 AM   #2
Mt Man Chad
Mt Man Chad's Avatar
Re: Sway bar installation question..
YEP!
The bigger head on the rivet is on the top of the frame rail.
So grind from the bottom and hammer them out!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 02-10-2008, 02:02 AM   #3
DennyB
DennyB's Avatar
Great, Thanks!
I'll go get some bolts before I grind.
Old 02-10-2008, 03:43 AM   #4
DennyB
DennyB's Avatar
Should I grease the new bushings where the bar goes through?
I.M.O.M,W,J&C
Patriot Guard Rider
Old 02-10-2008, 11:16 AM   #5
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Depends on the bushing you use. If you are using an OE style rubber bushing, slime it up a little bit, but I would reccomend going with a polyurathane bushing from a company such as Energy Suspension. They are greaseless and last a lot longer. Hope this helps.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 02-10-2008, 11:17 PM   #6
DennyB
DennyB's Avatar
Thanks,
I picked up a set of Moog poy bushings and the instructions said use no lube.
I.M.O.M,W,J&C
Patriot Guard Rider
Old 02-11-2008, 07:55 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Originally Posted by DennyB View Post
Thanks,
Denny, I also used Moog bushings and didn't use any lube. My dad got his from ECE and his has little grease fittings built into them.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-11-2008, 08:33 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Moog here also, no lube
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-11-2008, 08:34 PM   #9
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Gotta have lube.
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
