Old 03-24-2002, 01:38 PM   #1
Chevy00
Post 350 Timing
I need timing figures for a '71 Cheyenne w/ 350 & automatic. After replacing the stock distributor, I set the initial advance at 8 deg w/o the vacuum advance connected. It runs nice, but I am wondering where it is really supposed to be? Any help is appreciated.
Chevy00 is offline   Reply With Quote
Old 03-24-2002, 02:16 PM   #2
Chevyman69
Vortec 350's Suck
Post
I assume you replaced the stock distributor with HEI. Either way an HEI equipped SB 350 that is stock or even a little warmed over runs great at 8 degrees, thats where I set mine too.
69 CST 10, 402, steel crank, heavy rods, Federal Mogul Forged Pistons, 9.9:1 compression, polished ported 781 heads 2.19/1.88 manley stainless valves, Crane Powermax Hydraulic roller 288/296 and .587,.610 lift, hardened pushrods, Crane Roller Rockers, Weiand Action Plus, 750CFM Rochester QJET, MSD HEI, MSD 8MM Wires, Dynomax Ceramic coated headers, should be about 500 H.P. 700R4 2500 stall, pretty nasty shift kit, 373 Auburn Pro Series Posi, buckets/console air/tilt/tach 4wheel discs
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, loaded, 350 Accel filter/cap/rotor/coil/AC Delco wires/AC Delco RapidFire plugs, Edelbrock intake and headers, 180 degree thermostat, Hypertech Thermomaster Chip, true duals 700R4 with B@M Shift Kit for now!
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
Old 03-24-2002, 04:35 PM   #3
69 longhorn
Post
On a stocker with HEI,I would try a 10-12 BTDC setting. listen to what the engine wants,go pull a few hills.....if it spark rattles,its too much. If you dont have enough timing,it will put a dent in perfomance/milage........69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-24-2002, 07:22 PM   #4
704x4
Post
well said 69 longhorn
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
