Old 02-14-2008, 07:29 AM   #1
Ace in the hole
Power steering question
I am starting to think my steering pump is bad. I am getting my truck back together but not ready to fire it back up yet. I put the steering pump back on and thought I would re-prime it and have it ready to go. Thought I could just spin it by hand and move the fluid thru the system but it did not work. Thought it might need more speed so I chucked an old pulley in a drill, ran the belt around it and the pumps pulley and spun it, both forward and reverse - still nothing. Am I missing something or is my thinking right and my pump is shot?
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 02-14-2008, 08:34 AM   #2
JimKshortstep4x4
Re: Power steering question
I have never tried what you are trying to do but from what I have seen the pumps very seldom go bad so I would still try it on the truck.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-14-2008, 09:14 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Come to think of it, in all the cars and trucks I've had, I don't think I've ever had one go bad either. Noisy or leaky, yeah, but not to where they wouldn't pump fluid.
I think Jim is right. When you get it all ready to go, hook it up and test it. If it still doesn't work then chase it from there.
68gmsee is offline   Reply With Quote
Old 02-14-2008, 09:25 AM   #4
Ace in the hole
Ya, I have never had one go bad either. I have it mounted on the engine, all hooked up and thought I would pump the fluid back through the lines but I guess I can't. I can't figure it out unless there is some kind of clutch mechanism inside and I'm not spinning it fast enough.
Old 02-14-2008, 09:31 AM   #5
DavesRide
DavesRide's Avatar
The pump is pressure sensative by means of a valve. If it isn't asked to do work like (trying to move pitmnan arm under load of tires) it won't. If it isn't actually powering the gear box it doesn't do anything as far as moving fluid other than lubricating itself.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 02-14-2008, 10:16 AM   #6
Ace in the hole
Ok thanks, that makes sense. It was bugging me because I was reading the shop manual and the process for filling the system with fluid. It states to start and run the engine for 2 or 3 seconds, shut off, fill the pump and repeat until the level stays the same. Then proceed to run the engine and turn the steering from one stop to the other several times and check again. I thought I could at least fill the system and get it close by hand.
Old 02-14-2008, 10:47 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Very true--- Here's a link in How stuff Works that explains the theory. Amazing how much info is in the "How Stuff Works" site. I've used it to show pics of engine inner works to the nephews. Simplistic and has good pics. If you scroll down it explains what DavesRide is saying.
http://auto.howstuffworks.com/steering4.htm
Old 02-16-2008, 06:26 AM   #8
bartstoy
bartstoy's Avatar
Had them leak and squeek but never go bad. Still running the original from my SBC on my BBC. Lost the cap a couple of times, but that's it.
Original owner '69 C20, long, fleet.
454 BB with Edelbrock stuff.
Work truck for years, 2nd restoration going on.
'69 C20
'03 Tahoe Z71
70 Hp Johnson pushing aluminum bass boat.
All things in life are uncertain, so eat dessert first.
bartstoy is offline   Reply With Quote
Old 02-16-2008, 06:45 AM   #9
Ace in the hole
Quick update- got it working. I had the motor almost ready to fire up so I got it ready and hot wired it. Got it purring like a kitten and the steering pump started pumping, all is good.
Old 02-16-2008, 08:06 AM   #10
68gmsee
Active Member
68gmsee's Avatar
Alright! Nothing like when you first crank it, and it starts up and you get it going.
