Old 02-14-2008, 08:37 AM   #1
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Steering Splines
I'm prepping my part orders for my week long thrash in March, and that involves some steering u-joints, hence I have a few questions.
What is the spline count on a 1970 Manual steering box?
What is the spline count on a 1970 Non-tilt steering column?
Thanks for the help, I'll make sure to do a thread during the week long thrash to slam this baby further into the pavement.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-14-2008, 09:05 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Steering Splines
Column is 3/4"-36 spline. Box will be either 3/4"- 30 or 36 spline. What are your plans?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-14-2008, 01:06 PM   #3
lowrollin70gmc
Too many projects
The current plan:
This weekend (I have Monday off), build a fuel tank for under the bed and possibly flip hood, prep for March.
In March:
The truck is currently bagged, but it leaks and I didn't use quality components the first time around, and I want it lower and will be working 6am-9pm daily thrashing to accomplish the following:
Section front crossmember 2" and relocate 1" forward.
-Move steering box and pitman arm up 2" and 1" forward to match
-redo lower a-arm cup (mold in bag mount)
-new steering linkage
Make new tranny cross member/modify stocker
-not sure exactly how yet
-3 speed stick (bell housing mount currently)
Clearance trailing arm cross member for exhaust
-Also flatten bottom for ground clearance
-Keeping 2 piece drive shaft, so I'll check the angles and see where it needs to go vertically to maintain good angles.
KP Components step notch rear to lay on 29" tire
-Redo rear trailing arms
--Modified stock or 2x2" tube, need to draw up plans still.
-Watts Link to locate rear (speedway motors).
-Bag mounts somewhere on stock arms, but not stock location.
-Shock mounts, possible located to use stock shocks.
York 209
I already mounted a York 209 on the engine and have the existing Viair compressor as a switched emergency backup.
Rough clearance the bed for notch and wheels.
Hopefully that can get done in my time frame so I can enjoy my truck before going to boot camp this summer.
Andrew
