Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-19-2008, 12:47 AM   #1
dadsbrew
dadsbrew's Avatar
Question Need help with code 25
hope some of you can help me out. I have a 88 s10 with 4 cyl. starts fine and runs good cold but when it warms up it starts stumbling and cutting out, its hard to keep it running. I changed spark plugs, cap, rotor, plug wires. It still throws code 25. Any Ideas ?
1970 K-10 400CID, to much cam--not enough compression Stan's Headers and a 4" lift / 1990 R1500 Suburban 4X4, 350CID with vortec heads, edlebrock intake, TBI, 10:1 compression and Stan's Headers
"The probability of someone watching you is directly proportional to the stupidity of your actions"
dadsbrew is offline   Reply With Quote
Old 02-19-2008, 03:39 AM   #2
89 crew
Re: Need help with code 25
I did a bit of searching and I found a code 25 is a Intake air temp sensor error. Is that what you have a code 25 as?
89 crew is offline   Reply With Quote
Old 02-19-2008, 04:10 AM   #3
C.W
Check for a broken or dis connected wire. I believe on those its in the air cleaner housing. If that all looks good replace it and clear the codes. It should be fine after that. I had the same problem with my astro van when i put the small block in.
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver.
86 Short box just starting the build.
86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come!
98 Cheyenne Ext cab short box 2wd. Driver and maybe future project.
C.W is offline   Reply With Quote
Old 02-19-2008, 06:54 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
we are talking a 2.5 right? the IAT is in the intake manifold.
68C15 is offline   Reply With Quote
Old 02-20-2008, 07:26 AM   #5
dadsbrew
dadsbrew's Avatar
Thanks guys, yes it is a 2.5 and my plan is to replace the intake manifold air temp sensor and go from there.
