Old 02-19-2008, 08:07 PM   #1
bowtiegreg
3 on tree trouble
anyone have insight for my troubles which are shifting gears with my 3 on tree. Looks to me like I am missing a guide pin that helps hold stuff together, but I am also having trouble with column as the steering wheel can be pulled in or out somewhat due to a worn out rag joint? The connection between the two shafts?
bowtiegreg is offline   Reply With Quote
Old 02-19-2008, 08:34 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 3 on tree trouble
Can you give a little more info? Can't help unless we know what problems you are having shifting. There's some guys here that have more knowledge of steering columns but I'm sure they need to know more...
And, definitely, the up and down movement of the steering column is not normal and may be part of the problem.
68gmsee is offline   Reply With Quote
Old 02-20-2008, 12:26 AM   #3
northerngmc
northerngmc's Avatar
Here is a thread that is posted in the FAQ section. http://67-72chevytrucks.com/vboard/s...d.php?t=215307
It has photos and shows how to adjust it. Maybe from the photos you can see if you are missing something.
Almost sounds to me like you are missing the spring in the end. On the bottom end of the column, where it connects to the steering shaft, there should be a pin or bolt holding a large flat washer in place and behind the washer is a spring.
Pulling the column out is fairly simple. Hardest part I had was getting the rag joint apart.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 02-20-2008, 12:50 AM   #4
northerngmc
Steering column diagram from the LMC truck catalog. Part 44 is what I am thinking you may be missing or not installed properly.
Blaine
