Old 02-23-2008, 02:14 AM   #1
liv4fun
liv4fun's Avatar
Talking Front Diff Question
Hello All. I have a question that I can't find the answer for. I know someone here knows.
How can you tell the difference between a Dana 60 front end and a Dana 44? Without looking at the hubs. I understand some people put Dana 60 hubs on a Dana 44 diff. I would like to know for sure what front end I have. I have a Corporate rear end. Can anyone help???
Thank You
Troy
[Little Brother of Blue'72]
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
72' Chevy 3/4 ton 4x4
99' Dodge Durango
89' Honda Accord - Commuter
liv4fun is offline   Reply With Quote
Old 02-23-2008, 02:45 AM   #2
Blue'72
Skinned knuckles
Blue'72's Avatar
Re: Front Diff Question
This may need to be moved to the truck forum or maybe the 4 ba 4 section..
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 02-23-2008, 04:39 AM   #3
1969k10stepside
Does it have 4 u bolts holding on the axle or just 3?
Here's a DANA 60 front axle.
1969k10stepside is offline   Reply With Quote
Old 02-23-2008, 05:08 AM   #4
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
Count the Ubolts, 4 on a 44 and 3 on a sixty
www.hilbillytruckpulling.com
hilbilly is offline   Reply With Quote
Old 02-23-2008, 08:52 PM   #5
Yukon Jack
Yukon Jack's Avatar
Attachment 338814
Hey! I recognize that axle
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-23-2008, 09:20 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Also, looking at the housing from the front. There should be a 60 or a 44 cast into the housing to the lower right of the cover.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-23-2008, 10:05 PM   #7
LONGHAIR
The pad where the steering arm bolts is different too. The Dana44 uses 3 bolts in a curved line, the Dana60 is 4 bolts in a square shape.
LONGHAIR is offline   Reply With Quote
Old 02-23-2008, 11:23 PM   #8
Burt4x4
Burt4x4's Avatar
"I understand some people put Dana 60 hubs on a Dana 44 diff."
Never heard of that, I don't think that is even possiable.
D60 has Kingpins, little dome ontop of the knuckels with a zerk fitting in the center. D60 is only 8lug and the hubs are HUGE compared to d44 and ya only 3Ubolts = pass side has one ubolt and two bolts holding the spring pack to the axel.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-26-2008, 11:08 PM   #9
liv4fun
liv4fun's Avatar
Thank you all for your help. The hubs on it are definetly much larger than a normal Dana 44 like what was on my last truck. I will try to post pics later. Also will check out other things listed above. I did notice the other day on the top right of the diff it had stamped backwards and upside down C-31625 or something along those lines. I will check for the 44 or 60 down on the bottom also. Will keep you posted.
Thanks again.
Troy
99' Dodge Durango
Old 02-27-2008, 04:45 AM   #10
shilo
shilo's Avatar
they did make big hub 44s. I think the early 70s 3/4 tons. Im not sure. I have one in my 71 and think the only difference is the external bolt hub. so the hub has gotta be bigger to accept the bolts instead of a integral hub with splines.
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 02-27-2008, 05:01 AM   #11
liv4fun
liv4fun's Avatar
Well as promised here are the pictures. After scraping the gunk off the bottom of the diff I saw where it did say 44-5F. Definatly a Dana 44, but here are pics of the hubs. They measure 4.5" in dia. They are factory Spicer hubs I do know that. I would say they are large hub 44's.
Thanks again for everybodys help.
99' Dodge Durango
Old 03-01-2008, 06:14 AM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That is a Dana 44 HD. It has the big hubs like mentioned, and another thing is that they have larger axle tubes. Be careful, the cast carrier housing on these can be weak. The housing axle tube bores were machined larger to accept the larger axle tubes and the housings are none to crack or break there.
