Old 02-24-2008, 07:28 AM   #1
Hart_Rod
Hart_Rod's Avatar
Big block Chevy parts
@@@@ MORE PARTS ADDED @@@@
** Parting a 70 GMC Custom Factory Big Block. **
** If you see anything in the pictures I haven't listed let me know and I will price. **
4 Core Radiator for auto tranny - $80
Shroud - ** SOLD EIGHTBANGER **
Turbo 400 shift linkage - ** SOLD SS396 **
400 shift solenoid - ** SOLD JQ-72 **
Power steering pump, reservoir and brackets - $225
Alternator brackets - $75
Auto tranny cross member with e-brake cable brackets - $40
3/4 T Master cylnder with power booster and proportioning valve - $40
Front sway bar - $35
Steering sector -$40 (No Shipping)
Dual saddle tanks with all switches and connections - $100 o.b.o. (No shipping)
Breather stove pipe tube w/ exh shield - ** Sold Sameyrasme72 **
All prices are plus shipping.
Hart_Rod is offline   Reply With Quote
Old 02-24-2008, 07:31 AM   #2
jamie72
jamie72's Avatar
Re: Big block Chevy parts
what year bb stands?? interested if 72`s
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 02-24-2008, 07:35 AM   #3
Hart_Rod
Hart_Rod's Avatar
All parts are from a 1970 GMC. More pics....
Old 02-24-2008, 08:02 AM   #4
396 SS
396 SS's Avatar
do you have all the pieces for the shift linkage
396 SS is offline   Reply With Quote
Old 02-24-2008, 08:08 AM   #5
Hart_Rod
Hart_Rod's Avatar
I didn't take it apart so refresh my memory on the total number of pieces. They should all be there, but let me check.
Old 02-24-2008, 08:26 AM   #6
396 SS
396 SS's Avatar
I don't know for sure how many pieces , the piece that is on the transmission, the piece on the frame, mabe a piece that goes between with a spring , and the rod from the column
Old 02-24-2008, 10:28 AM   #7
CCCC
CCCC's Avatar
Hello. Do you know if the brake MC, prop valve and the vac booster are in good working condition? Also would be interested in the T400 linkage if it all is there. I live in NM and couild pick up.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 02-24-2008, 10:34 AM   #8
JQ-72
JQ-72's Avatar
Rob, I'm needing the trans kickdown switch and wiring (it's hanging over the brake booster in picture #5)Thanks!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 02-24-2008, 10:37 AM   #9
Classic Bowties
Always on the hunt...
Interested the set of towers, the alternator brackets if you will separate and also interested in both crank pulleys and the water pump pulley pending pics & price. Lmk, Cb
Classic Bowties is offline   Reply With Quote
Old 02-24-2008, 05:54 PM   #10
DANTIP
DANTIP's Avatar
Could you post a photo of the stove and heat pipe? I want first chance on it.
Dan
DANTIP is offline   Reply With Quote
Old 02-24-2008, 06:09 PM   #11
Hart_Rod
Hart_Rod's Avatar
Dan
Here are the pictures of the stove pipe.
Old 02-24-2008, 06:13 PM   #12
Hart_Rod
Hart_Rod's Avatar
It all worked fine when the engine was pulled 2 weeks ago. SS396 has first dibs on the brackets, you'll be 2nd.
Joshua
Let me take a look at it and make sure it's OK. If it is, I'm not really sure what to price it at?
Let me check the pulleys and make sure they are OK. Are you interested in a package deal for complet p/s setup, pulleys, alt bracket and motor stands?
Old 02-24-2008, 10:44 PM   #13
sameyrasmea72
sameyrasmea72's Avatar
If Dan passes, and you have the base (pics Please), that goes with the pipe, I will take it. .................Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-24-2008, 11:32 PM   #14
Matt72blaze
Matt72blaze's Avatar
hey, how much for the radiator and shroud shipped to 85242? it is a 4 core right?
thanks,
matt
1970 C20 now a K30
1986 3+3 Dually
Matt72blaze is offline   Reply With Quote
Old 02-25-2008, 12:28 AM   #15
Hart_Rod
Hart_Rod's Avatar
I have both pieces. I'll post pics later.
thanks,
matt
I will guess between $40-50 for shipping, so $200-210.
Old 02-25-2008, 07:37 AM   #16
Hart_Rod
Hart_Rod's Avatar
I found 4 pieces which I think is all there is. Let me know.
R/
Old 02-25-2008, 07:42 AM   #17
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
PM Sent re Shroud
Put me down for the shroud if Matt passes.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 02-25-2008, 08:30 AM   #18
Hart_Rod
Hart_Rod's Avatar
Dan
Here are pictures of the base.... Dan 1st, Jason you're second.
Originally Posted by eightbanger View Post
PM Sent re Shroud
8banger, you're second. I've never shipped to the UK before.........
Old 02-25-2008, 06:59 PM   #19
396 SS
396 SS's Avatar
R/
I'll take it , let me know where to send the money.
Old 02-25-2008, 07:21 PM   #20
Hart_Rod
Hart_Rod's Avatar
Joshua
It should ship out Mon or Tue. Thanks and let me know when you get it.
Thanks, PM sent with details.
R/
Old 02-26-2008, 04:26 PM   #21
Hart_Rod
Hart_Rod's Avatar
Ttt
Old 02-26-2008, 05:31 PM   #22
396 SS
396 SS's Avatar
Thank You , PM sent
Old 02-26-2008, 10:20 PM   #23
Hart_Rod
Hart_Rod's Avatar
Jason - Dan passed, it's yours. PM sent with info.
SS396: No thank, you . I'll get it shipped out this week.
Old 02-26-2008, 10:45 PM   #24
1972Ryan
Still have the radiator? Also how much shipped to 28787?
1972Ryan is offline   Reply With Quote
Old 02-26-2008, 11:10 PM   #25
Classic Bowties
Passing interest on all of the above due to no pulleys being available in the package. Thanks, Cb
