Old 01-20-2003, 03:35 PM   #1
swdobbs
Relocate or trim the neutral switch?
The swap from a 4spd to auto is done, however the auto column (van/non-tilt)has the safety switch /brake pedal arm clearance problem.
Anybody have a more detailed description of the fixes.....I already screwed up and trimmed too much off the side of one switch after misreading an old post.
thanks in advance,
swdobbs......
swdobbs is offline   Reply With Quote
Old 01-20-2003, 05:30 PM   #2
junkyardjohn
junkyardjohn's Avatar
Lightbulb
I'VE DONE THEM BOTH WAYS. YOU CAN RELOCATE IT LOWER ON THE SHAFT, WITCH IS JUST A MATTER OF A LITTLE DRILLING & GRINDING WITH A DIE GRINDER OR DREMMEL TOOL. OR YOU CAN JUST JUMP THE SWITCH ENTIRELY (THATS WHAT I'VE DONE ON MY TRUCKS) BY MAKING A JUMPER, AND BYPASSING THE PURPLE WIRE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-20-2003, 11:16 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I did away with mine too...none of my trucks ever had a safety switch before, nor back up lights.
I'll probably address the problem at a later date...actually, i probably won't, but I like to think I will.
Old 01-20-2003, 11:58 PM   #4
minibike
minibike's Avatar
What problem...I have a van tilt auto column that I would like to use the switch on...will it interfere with my brake pedal? I haven't installed the column yet.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 01-21-2003, 12:08 AM   #5
Longhorn Man
Yes, the switch will be in the way when you go to bolt it up. You need to move it lower on the column. I'm thinking (which means rough guess looking at fuzzy memorys in my head) about 6 inches south oughta do it.
