Texas Big Wig
Brake help...
Idk if this is the right section to put this in, but here it goes
I was wondering if the brake booster & MC off a 85 1/2T will work on my 77 1/2T, other than the possibility of Metric Vs. American I don't see why there would be any difference between the working wise, just different materials / look Thanks, Matt |
A guy with a truck
Re: Brake help...
I don't see why not. The front and rear brakes are the same stuff, but you will definitely run into brake line differences (metric/standard.) I'm sure this has been done before? Dunno- take this as moral support/free bump...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Texas Big Wig
Re: Brake help...
Thanks man
I have no worries on the metric vs standard, as I have the double flaring tool to build my brake lines & I have to build new ones anyway Thanks for the support lol |
Re: Brake help...
The newer master cyl might have the GM 'quick take-up' design vs. the old unit. I'm not sure if there would be a variance in the prop valve to accommodate this so I would use the later prop valve as well.
