Wheelin' and Dealin'
best way to bag my 65
not very familiar with the bagging system only seen it on shows and otehr trucks and cars, i was thinkin of doin it to my 65 c-10, but how low could i go with out the c notch in the frame, and where can i get the best deal on them at and who are some of the top names so i can shop, and also pics would be nice to see of the process
thanks alot guys, LZ ![]()
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
Re: best way to bag my 65
http://www.streetbeatcustoms.com/artarr21800-sy.html
is this it a good application for me, how low can i go with this?
That is a very good DIY kit. Everything bolts right up and eliminates the headaches. Let us know if you have any questions. All of the guys here are very up to date on air ride and will help you thru your purchase.
http://streetbeatcustoms.com 1-800-420-5060 toll free order line Air Ride Headquarters |
A guy with a truck
***************** for front plates/cups and bags. Also check out Mr.Shelly's thread in the FAQ for pics on the install. You can bag your truck on the cheap this way(~$500) without spending all the dough on a "kit".
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
***************** is the perennial favorite around here ... never heard of streetbeat
Heard of streetbeat, but yes suicide doors is awesome, but my favorite is thebagshack.net good friend owns it, good guy.
#7 | |
Seρor Member
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
well could i get a total list of what i need for that 500 dollar one cause i have that now, i was planning to paint the body and then over the summer i was gonna bag it,
but i m still trying to get it asap, also my biggest question is how low can i go with out putting in a c notch in the frame, i dont need the best of everything thanks for the replies
A guy with a truck
Slam Specialties RE200 bags 7"- $75ea x4 = $300
***************** front cups/plates = $60 Firestone air line service kit- $30ea x2 = $60 1/2npt to 1/4npt reducers- $2ea x2 = $5 Miscellaneous grade 8 fasteners ~$20 That's about $450 and will pretty much equal a 3"/5" drop at ride height. I would also recommend shock relocators and new shocks as well as an adjustable panhard bar while you're doing it. The relocators are $60 from either ECE or CPP. Shocks- everyone uses the cheap Monroe Sensa-Tracs. For a little more dough, you can go quite a bit lower. 2.5" Drop Spindles = $250 2" lowering blocks = $75 CPP bolt-in notch = $100 -Chris
Its more than a 3/5 drop on the 65's and 66's... My back bumper I believe sat about 4 inches off the ground w/ no notch but some firestone 2600's in the back in stock location. I think that's more than a 3/5 drop but sadly I didn't measure beforehand. Lemme know if u want pics of the height or anything, I've got a few from before I notched mine.
1972 Chevrolet SWB
With the ease of these c-notches on c-channel frames I dont see why anyone would want to have the axle tag the frame on occasion instead of making the proper clearances. Yes I know bumpstops are there to quieten the blow but how many times do you want to hit that knowing how hard it hits.
Im just the kind that looks under these trucks or cars lowered and want to make sure I have enough clearances everywhere and a c-notch isnt going to make me blink twice. |
#14 | |
#15 |
1972 Chevrolet SWB
I hear alot of questions either here or on other boards about lowering trucks and the question always comes up "Do you have to notch the frame on a 6" rear drop??" Or 5" rear drop and so on.
I did my 2-4 drop on my Ram when only one kit was available and the same nite I finished the drop I looked underneath at ride height and told myself theres no way I am ever going to be happy with that much room between the axle and bumpstop with our crappy roads. The very next day i was c-notching the frame and never once looked back as that being a bad decision.i did the notch on that frame before a kit was out because those frames are hydro formed 360 degree boxed frames and universal ones werent out...........and those frames are way way toughter to c-notch than a c-channel frame. I also have a bad back as of 3 years ago and I have driven some very harsh drops in my time(customers and friends) and will not ever have a dropped car or truck of mine ever have a rough ride like those did.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. Last edited by slammed1; 02-28-2008 at 08:51 AM. |
#16 |
My axle in my s-10 sat about a 1/2" from the frame for a bout a month... What a PITA. It seems every 2 seconds it would be bouncin off of it.. Also my buddies truck frame cracked in a spot. We dotn know if it was from bottoming out or not but I am sure if was def. a good factor in it.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
#17 | |
#18 |
Yea that was riding low..
#19 | |
thanks alot guys
#20 | |
#21 |
looks good man thanks so now all i gotta do is change my exaust and build up my money again
#22 |
#23 |
LAIDOUT
Chris, is that a good choice vs. the very expensive adjustable shocks? I am running the old shocks that came with my 3/5 static spring drop from ECE. This is my first air ride truck and I have never ridden in another air ride truck [not very many up here in the mountains] so I don't have a reference point but I think the front of my truck rides kinda rough unless I go down below 80 lbs in my 2600s. I would like to go with a different shock but wasn't too excited about spending $500 on adjustables.
Added; Found this thread, so people like the Sensa-tracs, good to know; http://67-72chevytrucks.com/vboard/s...d.php?t=280692 Last edited by BigSky71; 03-03-2008 at 07:21 AM. |
#24 |
A guy with a truck
Yep. You can even use the cheaper Monroe-Matics. That's what comes with all the ART kits- just with an ART sticker on them...
#25 | |
LAIDOUT
