power steering
is a 4wd power steering box from a 1976 chevy the same steering box as the
2wd box |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: power steering
No, they are not the same, that includes every year from 73-87(91)
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
One shot, one kill.
Re: power steering
Capt is right. GM uses "800" steering gear in all its light duty trucks up to 1 ton. Difference is sector shaft diameter and wheather box is mounted inside or outside the frame. Internally they are the same. Also to be noted, be careful of fluid line attaching thread diameter and pitch. They changed over to metric but I don't remember when this was done. Easy to check though. If it's metric the wrench that fits it will tell you. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Re: power steering
I think it was in 1981 when they went to metric.
