Old 02-28-2008, 04:54 AM   #1
b.sharp
b.sharp's Avatar
disk brake question
I have read the threads on disk brake conversions, but does anyone know if a 89 suburban disk brake will work? It seams to be the same frame as the 87 trucks. I can get a sub frame pretty cheap but do not want it if the bake set up will not work on my '65 1ton. Any help with this would be greatly appreciated.
Thanks in advance for any help.
b.sharp is offline   Reply With Quote
Old 02-28-2008, 05:49 AM   #2
badriand
badriand's Avatar
Re: disk brake question
73-87 is the model yrs. I think the main part is will the control arms mount up if so then the rest of it should not be a problem. I used an 87 sub and bolted right up. Going to be hard but measure the width of the lower and upper control arms and check were they bolt to frame and make sure the aligment is the same for the holes, if it is then your probably good. I went out and checked mine center to center on my upper arm bolts and it looks like it is 5" exact.
badriand is offline   Reply With Quote
Old 02-28-2008, 06:11 AM   #3
David Flores
David Flores's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=263983
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 02-28-2008, 07:05 AM   #4
b.sharp
b.sharp's Avatar
bariand, Thanks for the info. I don't think they changed the frames on the subs until '91. but I wanted to know for sure.
David, I have read this thread several times, and it does state that the 88-91 sub and crew cab frames are supposed to be the same, but I wanted to see if anyone knew for sure if they would work.
I will check the 5" dim. with these. I can buy the front end of this sub frame for 100. including brakes calipers and all. All were in a driving truck three days ago. This sub was transfered to a 4x4 frame.
Thanks,
Old 02-28-2008, 09:57 AM   #5
joe231
joe231's Avatar
Yes, blazers, suburbans, and crew cabs had the same frame up till '91, '92 changed to the newer body style like the trucks, guess it took them a few years to complete the tooling changes. Joe`
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-28-2008, 09:58 AM   #6
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
suburbans and 1 tons are the same as 73-87 clear till 91, then the body style from 88 toke over the burbs and 1 tons.
kdrodworks316 is offline   Reply With Quote
