Old 02-28-2008, 06:16 AM   #1
ChevyDude
Front disc brake caliper rebuild
Hey guys is there a link to a detailed front caliper disassembly/rebuild? I took mine apart so I could powder coat them but can't seem to figure out how to remove the outer rubber dust boot??? Any help and or pics would be appreciated.
Alex
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 02-28-2008, 06:29 AM   #2
BurnoutNova
BurnoutNova's Avatar
Re: Front disc brake caliper rebuild
is the boot attatched to the caliper itself? i havnt taken truck calipers from a 71-2 apart but on sime newer stuff i deal with at work there is just an o ring around the piston
do you have any pics of it?
BurnoutNova is offline   Reply With Quote
Old 02-28-2008, 06:53 AM   #3
slammed1
1972 Chevrolet SWB
slammed1's Avatar
You have a dust boot type seal on the outer perimeter of the caliper bore itself which has a metal lined oring for a press type fit,once the piston is removed the outer dust boot pops out with a small screw driver,then you can use a curved pick or small screwdriver to remove the actual seal for the piston.
Once the inner and outer seal are removed,you need to thoroughly clean the inside of the caliper and the outside of the piston very well. The new seal goes in with ease and needs lubed with brake fluid before trying to stab in the piston...........some guys like me place the new outer seal in right after the inner seal and use compressed air to blow up the outer seal to install the piston.........others with not much experience an install the inner seal then after wetting it down with brake fluid,can insert the piston to around 3/4 depth then install the outer dust boot. Always make sure the piston and seal are lubed with brake fluid and nothing else........wetting them with brake fluid assures a good fit and slides well.
here are a few detailed links.
http://www.inlinetube.com/install%20...%20Rebuild.htm
http://www.installuniversity.com/ins...er_rebuild.htm
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-28-2008, 06:55 AM   #4
slammed1
1972 Chevrolet SWB
slammed1's Avatar
If you attempt the air pressure method to remove the piston I suggest keeping fingers clear and use a controlled low pressure style blow type air set up. I generally use the air to pop them out but also use a few balled up rags pushed into the inside of the caliper so that the piston doesnt shoot out quite as hard.
Just a side note......for safety.
also the top link shows using Wd40 to lube parts up.......I just use brake fluid itself so that there is NO contamination.
Old 02-28-2008, 06:39 PM   #5
ChevyDude
so what is the best method to remove the metal O ring that locks on the outer rubber dust seal. The inner seal is cake to remove. I used air to blow the opiston out, cake...but don't get your fingers in the way! And who carries the two new seals???
Alex
Old 02-28-2008, 09:27 PM   #6
shifty
Questionable
shifty's Avatar
I learned how to rebuild a caliper on Trucks TV this last weekend. They got a $8 rebuild kit from the store which included everything, seals, etc. If it will help, I can pull that episode off my Tivo and crop out the pertinent part and send it to you, just let me know?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-28-2008, 11:17 PM   #7
ChevyDude
Thanks Shifty....but I just figured it out!
Alex
