Old 03-02-2008, 04:42 AM   #1
thump16
thump16's Avatar
ingnition coil and distributor wiring
Can some one please post pictures of the wiring that is supposed to hook up to the coil and distributor from the truck wiring harness. I unhooked the msd from my truck and trying to find out what goes where. There was a big pinkish red wire that was hooked up to the MSD. I thought there was supposed to be a white wire in the bundle.
thump16 is offline   Reply With Quote
Old 03-02-2008, 07:10 AM   #2
thump16
thump16's Avatar
Re: ingintion coil and distributor wiring
is the big pink wire I cut from the msd box the one that plugs into the distributor for power?
Old 03-02-2008, 07:36 AM   #3
85gmcguy
Plays with trucks
85gmcguy's Avatar
On the distributor itself there are only 2 hookups (other than from the distributor itself) one is Batt and the other is Tach. If you don't have a tach, it would probably hook to the Batt terminal. I'm not really sure about through an external (MSD) box.
If you're trying to eliminate the box, you just need to hook a wire to the batt terminal that is powered through the ignition (on when key is in run) .
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 03-02-2008, 10:29 AM   #4
thump16
thump16's Avatar
That is what I was wondering. There is one huge pink wire that attached to the mds box for 12 volts and I wanted to make sure that was the one I was supposed to hook up to the hei. I removed all of the MSD goodies to go on a buddies project. I plan on keeping my truck so I am going through and un rigging everything the PO had installed to include the fried fuse box.
Sledge
Old 03-07-2008, 06:19 AM   #5
capt. camaro
Re: ingnition coil and distributor wiring
The pink wire is the correct one to hook to the dist. terminal. Bob
capt. camaro is offline   Reply With Quote
