Old 03-02-2008, 12:32 PM   #1
BB6T7
Hey airbag guys...
A R T told me that their bags for the front of my 67, at ride height was the same as a 2 in drop spring. what I need is a bag that is the same as 2.5 in drop spring , so combined with my 2.5 drop spindle will give me 5 in drop up front. In back I got 6 in coils no c-notch. is there a bag for the back that will give a 7 in drop at ride height ? I dont want to use blocks cause of pinion angle issues. I know i will have to c-notch in back. Right now I would like to set and go, no compressor or tanks. does this sound do-able or not
BB6T7 is offline   Reply With Quote
Old 03-02-2008, 08:19 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Hey airbag guys...
uh.... let some air out of the bag?!?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-03-2008, 01:00 AM   #3
BB6T7
Yea i thought of this too but will it effect ride quality at a lower psi ?How much psi to raise or lower .5 inch? I am knew to this so thanks for your patients
Old 03-03-2008, 03:53 AM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Probably only a few pounds to lower it an extra 1/2" but I would suggest cutting the lower bag cups down to get the 1/2" you want... I cut mine down a little over an inch to get the front end lower.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 03-03-2008, 06:51 AM   #5
BB6T7
That sounds like a great way to fine tune my stance up front-thanks . How about in back where I need a 7 in drop? can I do that with bags only or do I need blocks too? Any suggestions for bags? RE7?, ART? Firestone?
Old 03-03-2008, 07:02 AM   #6
SCOTI
SCOTI's Avatar
7" drop w/bags only? Not that I've seen. Bolt the bags directly in place of coils & use lowering blocks & your there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-03-2008, 07:55 AM   #7
BB6T7
will I run into pinion angle problems with blocks? what about air bag suggestions? type/brand?
Old 03-04-2008, 03:14 AM   #8
SCOTI
SCOTI's Avatar
http://67-72chevytrucks.com/vboard/s...2&postcount=12
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2008, 06:43 AM   #9
Frizzle Fry
Frizzle Fry's Avatar
7" out back with no notch? Hold on to your teeth!
I have Slams RE7's in place of the rear springs and 3" blocks (only advisable with big rollers), and no pinion angle issues yet. I'm sure it's not optimum but there are wedges available to correct it if needed. With 1" blocks I wouldn't be worried.
Frizzle Fry is offline   Reply With Quote
Old 03-04-2008, 12:49 PM   #10
BB6T7
WOW, you guys are a great help thanks much. Now I just have to make time to work on it! Yes frizzle, its gonna get c-notched
Old 03-05-2008, 04:00 AM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
Here's a pic of my truck at ride height with the bags at the 6" recommended installed height with 1.5" blocks. I'd guess it's around a 7-or-8" drop. The notches are mandatory at this amount of drop...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-05-2008, 04:06 AM   #12
SCOTI
SCOTI's Avatar
Truck?? You have air on it too??????
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2008, 04:56 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
As of this past weekend... Click me. And yes, I do have a sickness...
-Chris
Old 03-05-2008, 05:11 AM   #14
Shane
Shane's Avatar
I'd love to see it too ... but i get this when i click your link ...
No Thread specified. If you followed a valid link, please notify the administrator
Shane is offline   Reply With Quote
Old 03-05-2008, 05:22 AM   #15
SCOTI
SCOTI's Avatar
Yea, that's what I got as well so I searches for threads started by Gringo.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2008, 05:30 AM   #16
gringoloco
A guy with a truck
gringoloco's Avatar
Fixed.
-Chris
Old 03-05-2008, 11:26 PM   #17
Hart_Rod
Hart_Rod's Avatar
You can also flip the trailing arm mounting brackets over. This will help with the pinion angle also.
Hart_Rod is offline   Reply With Quote
Old 03-06-2008, 10:51 AM   #18
BB6T7
So if I use a 1-1/2 block should i check for pinion alignment if so,what should it be? can I use a magnetic degree finder from somewhere like Harborfreight ? Would I put the degree finder on the tranny pan then on the u-joint cradels on the diff ? Does all this need to be done or am I just making a bunch more work for myself ?
Old 03-06-2008, 11:14 AM   #19
SCOTI
SCOTI's Avatar
My 68 was a swb w/a 1pc driveshaft, Firestone bags, & 1.5" blocks. I didn't use any shims. Service life so far on the u-joints is/was approx 25K miles (5yrs) w/o issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2008, 12:38 PM   #20
BB6T7
Hey thanks for info SCOTI, I put about 5000 miles per year on . Ill just keep an eye on it and feel for vibes. its swb and one piece drive shaft also.
