Old 03-02-2008, 01:19 PM   #1
64Magoo
What is the cost for baggin?
I'm getting a standard lowering kit for my 64 c20 lwb (3" front, 4" rear) but I saw a sweet '70 longbed sitting on the ground front and back today. Those of you who have done this what is the realistic price of getting my frame on the ground; including everything (i live in an apartment so labor would have to factor in.) I know I the prices will be all over the board but I just want a ballpark. Thanks!
64Magoo is offline   Reply With Quote
Old 03-03-2008, 03:47 AM   #2
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
Re: What is the cost for baggin?
you can select all your parts for a custom kit for pretty cheap here:
http://*****************/custom.php
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 03-03-2008, 04:16 AM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
If you want to get your frame on the ground, there will be a lot more work than just the airbag system. You would need to install a step notch in the back. Your inner fenders and wheel tubs would need to be modified and/or removed. The bed of the truck would have to be raised, etc, etc, etc...
If you wanted to install bags and slam it to within 6-8 inches off the ground, you would only need to have a c-notch installed, replace your coil springs with air bags, run some air line and find a place for your tank and compressor.
To start with, you could even eliminate the tank and compressor and install schrader valves to raise and lower the vehicle. You would have to inflate/deflate the system manually but I have seen 12V 200psi portable compressors for under 200 bucks that you could use out on the road and avoid having to stop at a gas station.
To answer your first question, you could probably buy a complete system with bags, brackets, c-notch a small tank and entry level compressor for under $1500.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 03-03-2008, 05:10 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Just to give you an idea of labor.....I would charge a board member anywhere from $500-1000 labor to install a "basic" kit.....custom c-notched and other work would be extra.
Anyone else would be $1000 on up for a "basic" install.
I'm sure you could find someone in town or Fresno to hook you up.
Otherwise, come see me !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-03-2008, 05:49 AM   #5
Slmd92DIME
Slmd92DIME's Avatar
ChiefRocka- How good of luck are you having with the Viair 480s? I have been seeing them a lot recently. I have 2 380s on my S-10 and have been thinking about a upgrade.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 03-03-2008, 07:28 AM   #6
greg64
greg64's Avatar
John, that's quite the watts linkage!
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-03-2008, 07:31 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Pretty good luck with them....however, if you check the specs, they're outputs are pretty much the same.
The 380 lists a 100/55% duty cycle....while the 480 is 100/50% duty and is 3 lbs heavier.
The 480 has a different head...with a tad more CFM
I have heard some people snapping the piston rods (480's), but nothing with my customers thus far.
Here are some specs:
380C Air Compressor (P/N 38033)
• 12-Volt
• Permanent Magnetic Motor
• Duty Cycle: 100% @ 100 PSI, 55% @ 200 PSI
• Max. Working Pressure: 200 PSI
• Amp Draw: 16 Amps
• Min. Ambient Temp: -40° F
• Max. Ambient Temp: 158° F
• Dimensions: 9.00” L x 4.00” W x 7.00” H
• Net Weight: 8.00 lbs.
380C Tank Fill Rates
2.5 Gallon Tank Fill Rate
0 To 145 PSI 3 Min. 48 Sec.
0 To 200 PSI 6 Min. 10 Sec.
110 To 145 PSI 1 Min. 12 Sec.
165 To 200 PSI 1 Min. 40 Sec.
0 To 145 PSI 8 Min. 35 Sec.
0 To 200 PSI 14 Min. 45 Sec.
110 To 145 PSI 2 Min. 42 Sec.
165 To 200 PSI 3 Min. 30 Sec.
The 380C is a truly-rated continuous duty, 12-volt, 200 PSI compressor. It is capable of filling a 5-gallon tank from 165 PSI to 200 PSI in 3-1/2 minutes consistently, while never pulling more than 16 amps of power (@13.8 volts). It is the choice for those who wish to keep the strain on their vehicles’ charging systems to a minimum. Features include a standard Ό” stainless steel braided leader hose with inline check valve and insulated wiring for simple installation. *Must be used with a 200 PSI or lower pressure, non-adjustable pressure switch when used with an air tank.
380C Performance Data
PSI CFM A bar LPM A
0 1.49 8 0 42.0 8
10 1.17 10 1.0 32.5 10
20 1.13 11 2.0 31.0 12
30 1.09 12 3.0 29.0 13
40 1.02 13 4.0 27.0 14
50 0.99 13 5.0 26.0 14
60 0.95 14 6.0 24.5 15
70 0.92 14 7.0 23.0 15
80 0.88 14 8.0 21.0 15
90 0.85 15 9.0 19.0 15
100 0.81 15 10.0 16.5 15
110 0.78 15 11.0 15.5 15
120 0.71 15 12.0 14.0 15
130 0.67 15 13.0 12.5 15
140 0.60 15 14.0 11.5 15
150 0.57 15
160 0.55 16
170 0.51 15
180 0.48 15
190 0.44 15
200 0.40 15 *Supply Voltage: 13.8 Volts
[click photo to enlarge]
480C Air Compressor
(P/N: 48040)-Pewter
(P/N: 48043)-Chrome
• 12-Volt
• Duty Cycle: 100% @ 100 PSI, 50% @ 200 PSI
• Amp Draw: 19 Amps
• Dimensions: 11.50” L x 4.30” W x 6.50” H
• Net Weight: 11.00 lbs.
480C Tank Fill Rates
0 To 145 PSI 2 Min. 29 Sec.
0 To 200 PSI 5 Min. 02 Sec.
110 To 145 PSI 57 Seconds
165 To 200 PSI 1 Min. 23 Sec.
0 To 145 PSI 6 Min. 02 Sec.
0 To 200 PSI 10 Min. 08 Sec.
110 To 145 PSI 1 Min. 55 Sec.
165 To 200 PSI 2 Min. 20 Sec.
The 480C features include horizontal cooling fins and a trapezoidal head design, a standard 3/8” stainless steel braided leader hose with inline check valve and insulated wiring for simple installation. * Must be used with a 200 PSI or lower pressure, non-adjustable pressure switch when used with an air tank.
480C Performance Data
PSI CFM A bar LPM A
0 1.76 10 0 50.0 10
10 1.66 12 1.0 46.0 13
20 1.59 14 2.0 43.0 15
30 1.52 15 3.0 40.5 17
40 1.45 16 4.0 38.5 18
50 1.41 17 5.0 35.5 19
60 1.34 18 6.0 33.0 19
70 1.27 18 7.0 31.5 19
80 1.20 19 8.0 29.5 20
90 1.16 19 9.0 27.0 20
100 1.13 19 10.0 25.0 19
110 1.06 20 11.0 23.0 19
120 1.02 20 12.0 20.5 19
130 0.95 20 13.0 18.0 18
140 0.92 19 14.0 15.5 18
150 0.85 19 15.0 14.0 17
160 0.81 19 16.0 12.0 16
170 0.74 19 17.0 11.0 15
180 0.70 19
190 0.63 18
200 0.56 18 *Supply Voltage: 13.8 Volts
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-03-2008, 07:34 AM   #8
Slmd92DIME
Slmd92DIME's Avatar
I heard the 480s were A LOT quieter than the 380
My Build Thread
Old 03-04-2008, 07:52 AM   #9
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Realistically' your probably looking at around 2000-2500+/- to farm out the work.
Also, I don't know what kind of luck I'm gonna have here, but ditch those Viairs. I used to run two 380's. I didn't snap the rod on them, but one of the rods didd fall off the crank and killed that one. I now run one Air Zenith with a five gallon tank and LOVE it! Once you try a Zenith, everything else sucks except mabe an Oasis.
Imperial Kustom is offline   Reply With Quote
Old 03-04-2008, 07:53 AM   #10
Imperial Kustom
100% gearhead
Old 03-04-2008, 07:53 AM   #11
Imperial Kustom
100% gearhead
Old 03-04-2008, 07:53 AM   #12
Imperial Kustom
100% gearhead
Old 03-04-2008, 07:53 AM   #13
Imperial Kustom
100% gearhead
Old 03-04-2008, 07:53 AM   #14
Imperial Kustom
100% gearhead
Old 03-04-2008, 08:07 AM   #15
joe231
joe231's Avatar
WTF???
what happened, 5 copied posts???
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-04-2008, 08:08 AM   #16
David Flores
David Flores's Avatar
no need for 6 posts
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 03-04-2008, 08:37 AM   #17
Slmd92DIME
Slmd92DIME's Avatar
I have heard multiple times that the Air Zenith are not having too good of luck.... They have had so many problems with them I refuse to buy one.
My Build Thread
Old 03-04-2008, 06:33 PM   #18
protrash64
Resistance is Futile
protrash64's Avatar
........in the suspension section I posted a question about air compressors and 2 people said the air-zeniths failed after awhile. Thats 3 total that have the same story. FYI
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-05-2008, 08:42 AM   #19
Imperial Kustom
100% gearhead
Wow! Guess my p.o.s. computer got a bit carried away there! So far I have run the crap out of my Zenith. Not one single bit of trouble. I use so much air, that the thing hardly ever shuts off! It never even gets warm. Besides, now they have the OB1x, which has an improved head and integrated cooling fan.
