03-05-2008, 06:19 AM | #1 |
Spring is coming Have Plans for bed repair and suspension drop
I've had my 87 swb silverado for almost a year now. So far it's been a very reliable driver. All I had to do major with it, within the year, was replace the rotted driver side gas tank. This spring, I want to do more with it. The bed has some rot that needs to be addressed, which has gotten worse over just the year. While the bed is off, I plan on stripping the frame down, as best I can, and painting. I also plan on giving the truck a drop, not sure how much I want to go, I'll address that later. Thing is, I still need to drive this truck. Have any of you guys driven your trucks w/o a bed? How did you mount up your tail/turn signals? Is anything else required? I think in CT, if a truck has no bed it must have mudflaps? I need to make something temporary while I work on the bed, any ideas? I have included some pics of what I'm dealing with for rust. These pics were taken before the winter, and the areas have gotten a bit worse. All the vendors I have looked at, are all close in price, and fairly cheap. I was thinking about getting a pretty good bedside section, not a complete section, but enough, and just cut out what I need for patching. The back cross beam, where the bed bolts actually go through and bolt the bed to the truck frame, is almost completely rotted away. I can't seem to find these anywhere? It seems like a pretty basic concept, cut out the old beam, weld in a new one. Also, the tailpan section is in pretty bad shape, any tips on installing one of those? I have a good Lincoln mig welder, and my father has done body patching before, actually with his old 86 c10 with very good results, but we aren't really that knowledged with body work (body filler, getting it all to blend). This ain't gonna be a show truck but I would like the treated areas to be presentable so any tips would be greatly appreciated. Here are pics of what I'm dealing with.
Rotted wheel arch, it has gotten worse since this pic was taken Rust popping through on the same wheel arch Rust popping through, same bedside, in a rather odd spot, looks like this one should be fairly easy to tackle. WOW, that cross beam is GONE! What the truck looks like, presentable but boy does it hide some rust underneath that bed! |
03-05-2008, 09:16 AM | #2 | |
6.0 powered square
Re: Spring is coming Have Plans for bed repair and suspension drop
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
03-05-2008, 11:02 AM | #3 |
Sb 400 club
I have seen guys around here drive with no bed. All you need is a rear bumper and lights. Most just use a l shaped peice of metal and bolt it to a pre existing hole. The wheel arches suck man i bet there is more hiding in there then you think at least there was on my old 85 c10.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
03-07-2008, 05:11 AM | #4 |
I'm still undecided on which patch panels, I should get, or if that bed is even worth fixing? I was hoping for more responses! Anyways, that lower bedside wheel arch corner, most vendors sell them in 12 x 25''. Problem is, I think I need a taller section, since that rust creeps up that wheel arch as you can see in the pics. Should I order that patch, and a wheel arch panel and piece them together? That is my biggest concern. That bottom cross brace, and tailpan, are hidden, so it's just a matter of getting them welded solid, I have no problems with that. Just that damn wheel arch. I hate to throw in the towel and search for a better bed to work with, because although those pics make it look horrible, the rest of the bed, including the entire right side, is solid. Any tips?
03-07-2008, 06:05 AM | #5 |
Chris
You can buy a slip over tail pan replacement or the whole one to cut out the old and weld in.
Also you can get an upper arch and lower rear section or buy the whole arch section and it be plenty enough for you to fix what you need shown in pics, except for the front of the bed. For cross sills under the bed I seen them listed on back of my raybuck automotive book. I couldn't find them on their website last year but they got em on back of the book. Just look up raybuck automotive online. Worth saving, definately our 84 bed is rotted out worse and we are saving it. We just ground it down and filled with fiberglass and bondo, that was a year ago almost. Going to do a whole arch or new bedsides on it. We don't have a welder, so I thought cut it, flange it, then panel adhesive and rivet it in place. Not sure though, alot cheaper then besides but more work.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
03-07-2008, 08:24 AM | #6 |
Thank you Benoit for the information and opinions on bed! I always get mixed opinions from people on whether to scrap the bed or repair it. Like I said, if the passenger side was bad as well, I'd probably consider it but the rest of the bed is solid and it's tough to find a complete rust free 6.5 footer in New England for cheap. Then I would probably have to paint the entire new bed anyways so it's worth keeping I guess.
03-12-2008, 07:31 AM | #7 |
Chris
It's hard to find a short bed anywhere that's prone to rust for a decent price, and around here they want 2 grand plus for rust bucket trucks.
I never could find an s-10 short bed rust free or at least less then ours had, and the 76 we had and 84 we got now is the same way. My buddy however found a long bed for his s-10 for $75 had tailights and tailgate and they cut it off and loaded it up for him for that price. Now if they were bad enough I'd say replace the bedsides. I know how that goes though about $300 a side compared to what $20 a side for an upper arch repair?
03-12-2008, 08:47 PM | #8 |
Nice shorty! looks like mine but mines a 81
