Old 03-07-2008, 11:58 AM   #1
69long"n"low
69long"n"low's Avatar
has anyone brazed bodypanels
I was just wondering if you could braze patch panels and fill holes on body panels. the reason im asking is cause i have no welding experience and its a little more finacially fiesable to get a torch then a welder
thanks Josh
69long"n"low is offline   Reply With Quote
Old 03-07-2008, 04:00 PM   #2
Re: has anyone brazed bodypanels
I have.There was a time (before Mig/Tig) when that was the only way to go.
Old 03-07-2008, 06:42 PM   #3
68gmsee
Active Member
68gmsee's Avatar
I learned to braze back in high school (too many years ago) with an oxyacetylene setup. Works good but you have to be very careful with the thinner guages so you don't warp them. You have to preheat the metal that you're going to braze so that the rod will flow properly. This in turn may cause warping.
I was never real good with it. I'd say practice a lot on scrap metal first.
68gmsee is offline   Reply With Quote
Old 03-07-2008, 07:02 PM   #4
arkracing
Weekend Warrior
Lots of old cars had it done and then they had lots of filler on top of it
You can actually gas weld with an O/A setup. I think that it would be better than brazing, but as mentioned it puts alot of heat into the panels - high change of warpage.
If you are really, really, really, really good @ it (read: some of the old time customizers) it is a great way to weld body panels as the weld is soft and workable, unlike MIG.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-07-2008, 07:38 PM   #5
69long"n"low
thanks for your input it helps a lot
Old 03-07-2008, 08:30 PM   #6
mbgmike
Actually some of the new cars still have some brazing on them believe it or not. I know Toyotas do
mbgmike is offline   Reply With Quote
Old 03-07-2008, 09:45 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Myself, I wouldn't recommend it. I brazed pieces of metal in the dash of my '36 Ford to patch some holes and it cracked where they were put in. The torch set itself may be cheaper but by the time you get the oxygen and acyetelene (sp) bottles you will have as much money in the torch setup as you would in a small mig welder.
Just my 2¢ worth
LockDoc
Leon
Old 03-07-2008, 09:58 PM   #8
heavy71chevy
heavy71chevy's Avatar
yea warpage is most likely gonna happen...check ebay you can get 110v mig for a hundred bucks and alot safer this way
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 03-07-2008, 10:48 PM   #9
fine69
fine69's Avatar
You can get cheap migwelders nowdays.
Brazing sucks.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-07-2008, 11:21 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
I got a mig welder at Harbor Freight for $130 It's the simple wire feed (no gas needed.) You just need a certain type of wire (the name is escaping me at the moment.)
It kinda sucks, but it works well enough.
This is THE FIRST time I've ever used a mig welder.
Please ingnore the fact that the fender looks like someone took a hammer to it, I bought it that way But it was primed with 10 lbs of filler
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-08-2008, 12:22 AM   #11
mbgmike
Nothing wrong with brazing if you know how. Tom Young here in Houston at American Heliarc builds custom motorcycle fenders that run around $2000 each. He prefers to braze them. True oxy-acet will run you more for equipment, however nothing wrong with brazing. it just takes more talent
Old 03-08-2008, 12:42 AM   #12
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
i've brazed body panels...still do. Its just trying to get the puddle to move where you want it to...I still prefer mig welding...
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 03-08-2008, 05:05 AM   #13
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
"Flux-core" Wire welding without gas.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-08-2008, 05:35 AM   #14
Ol'Rover
Ol'Rover's Avatar
heh, i used that on my shelf framing when i didnt have gas for my welder. works pretty decent, better welds with gas tho...
Old 03-08-2008, 05:40 AM   #15
89 crew
I have found the quality of the oxy-acc torch will determine the amount of heat you put into the metal. If you are going to try it I would recommend either a good victor, or smith torch, with a small welding tip. Don't waste your money or time with a made in china torch.
89 crew is offline   Reply With Quote
Old 03-08-2008, 06:14 AM   #16
Rigo's 70 C10
What vehicle is that filler door from? It looks nice! Is that the front fender?
Rigo
Rigo's 70 C10 is offline   Reply With Quote
Old 03-08-2008, 06:39 AM   #17
Gorn
Gorn's Avatar
Brazing should be concidered a temp repair. Oxidation will occur between the Steel and Brass there is no way to stop it. Might hold together 5 year maybe 10 at the outside. This is why it has fallen into dis-favor with people who restore cars. It is still pretty common in crash and dent repair shops.
Normally what happens is the patch lifts a bit and cracks the putty. Water gets in the crack and then it all bubbles up with rust.
It is better to live one day as a Lion then 100 years as a Sheep
Dingers Build Thread
Dingers Before Pic's
My 67 Camaro
Gorn is offline   Reply With Quote
Old 03-08-2008, 07:17 AM   #18
crazy longhorn
Fabricate till you "puke"
I brazed a few back in the day(when puddy was my buddy). In the yrs before the mig welder, hammer welding was a true "art", It took a real pro to do it right Paddling lead was another part of that lost art......if you have ever seen that 85 yr old man on monster garage, with the big cigar in his mouth(probably not lit), that would be Bill Hines. Probably one of the last in his day, & has lead flowing in his veins, along with George Barris, & a few others that will truely be remembered as the pioneers(craftsmen) in custom body work(leadsleds).....this was before my time. Now I can go out to my shop, crank up a Mig & do some pretty nice work, as well as the rest of the "backyard bucks"......& really be in total awe, looking at what those guys did with rather crude equipment (by todays standards). Buy ,beg,borrow a good little mig, & go PLAY!.....you will be 40 or 50 yrs ahead of that old torch, & if you practice, be patient, you will have very little fill work to do. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-08-2008, 08:21 AM   #19
69long"n"low
thanks for all the advise are any of the cheap welder worth the money?
Old 03-08-2008, 09:50 AM   #20
LockDoc
LockDoc's Avatar
My '36 Ford Coupe was done in lead in 1961 and it looks just as good now as it did then....
LockDoc
Leon
Old 03-08-2008, 10:35 AM   #21
crazy longhorn
LockDoc
Anytime that a true craftsman does a job, its done to last.....man thats sweet! crazyL
Old 03-08-2008, 07:00 PM   #22
67ChevyRedneck
Ahhhh, thank you!
It worked well enough for me
Jesse James
Project "On a Dime"
Old 03-08-2008, 07:34 PM   #23
67ChevyRedneck
Rigo
Heck no It's the rear step fender on a '67.
The door is from an 88 to 98 Silverado. I believe the 90's something to '04 S-10's use the same door.
Finished product:
Jesse James
Project "On a Dime"
Old 03-08-2008, 11:12 PM   #24
MXmaniac
MXmaniac's Avatar
I remember hearing somewhere that you don't want to use flux-core wire on body panels because the flux will cause the paint to not adhere properly. Is this true?
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 03-09-2008, 02:06 AM   #25
CPNEJR
CPNEJR's Avatar
i don't think thats true. before we got a gas setup for our welder we did some body work on my 67 and have painted over where we welded. of course there is a small layer of bondo between the weld and paint which i would think is normal considering you will most likely want the panel to look and feel smooth
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
