rear tank filler, please help!
Hey guys,
I just installed the rear gas tank and I'm trying to decide how and where to place the filler neck. I've seen a few behind the tail light and I really liked it. If anyone could please post some pictures I'm desperately needing ideas. I have a steal bed floor so wasn't wanting to put it in the middle of the bed. Thanks for any ideas and pictures provided. -Nick |
Re: rear tank filler, please help!
mine is behind the sidemarker
common sense isn't so common anymore |
Some one just did this thread a couple weeks ago so you might do a search on it. Here's how I did mine
69 Chevy 4x4 383 Power ![]() |
![]() Join Date: Jul 2001
When I installed my under bed tank I had the some questions and decided to go this route. Not fancy, but quite functional if you still use the truck bed. Really a pretty easy install. Used parts from a early 90's Chev. Lumina Van.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Here's mine setup for dual tanks.
Mike K Friend of Bill W |
#6 | |
I did mine almost exactly the same way. I use a marine type filler to keep the profile low, and water tight.But the location is almost exact. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
Here the way I did mine.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
