Old 03-09-2008, 07:37 PM   #1
jd4300fel
jd4300fel's Avatar
tune up specs 72 bbc
Hello,
I am looking for the original tune up specs for my 72, it has a 400 bbc aand a 400 tranny. I have recently added an HEI. I currenly have it set at 10 degres BDC, @ 650 RPM. I am also replacing the plugs which I am planning on gapping at .045.
Any details will be appreciated. I did check the FAQ but could not find what I am looking for
Regards,
Mike
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 03-09-2008, 08:46 PM   #2
kenm78
Broken Down
kenm78's Avatar
Re: tune up specs 72 bbc
I have Mitchell on demand online tech manuals and the settings are all for points timing is set at 8 degrees and idle is at 600 rpms and .035 gap and this is for 402 bbc. The manual specifys 400 bbc in the repair side but not on the tune up section. If it is running good and you have no pingging go with what you have!!
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 03-09-2008, 08:54 PM   #3
kenm78
Broken Down
kenm78's Avatar
Ok did som more searching and found this
1976
400 BBC/454 BBC
Spark plugs light duty R45TS
Spark plugs heavy duty R44T
Gap for either is .045
Torque to 15 foot pounds
Timing is 8 Degrees BTDC.
RPM 600 auto trans.
kenm78
1982 Chevy 4X4
Project truck
Old 03-10-2008, 01:23 AM   #4
jd4300fel
jd4300fel's Avatar
Thanks for the help, I will try bringing the timing down a little moer and see what happens for kicksI might hook up a vacum gauge an see what that shows
Mike K
Friend of Bill W
Old 03-10-2008, 03:50 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'd stay with the higher timing if you aren't having any preignition problems.
