Old 03-10-2008, 07:39 AM   #1
c10hevy
c10hevy's Avatar
1.02 lateral g's!
What would it take for a swb 2wd to achieve such stats? Or somewhat close? What is the best suspension for performance oriented individuals out there? How well do bags perform when you dont care if you can slam your frame and tuck 22's? I want a truck I can take to the track and win against fox bodies or the like.
c10hevy is offline   Reply With Quote
Old 03-10-2008, 07:49 AM   #2
72LoBurb
Yup, I'm comp-useless
Re: 1.02 lateral g's!
That's a steep request from a pick-up, unless you are doing a full custom frame.
The weight bias of a pick-up is just so far from the ideal 50/50. Relocating the battery to the rear of the truck and a whole bunch of other mods to get the weight bias closer to 50/50 would help a bunch, then there is the whole issue of COG(centre of gravity). Drop that thing as close to the ground as you can, but still having useable suspension travel with as little deflection as possible(ie poly urethane bushings, full blown tubular control arms).
Anything is possible, as long as your wallet/bank has the fundage to allow the amount of modification needed to achieve these lofty goals.
1972 Chev Suburban(ongoing driveable project)
2010 Harley Wide Glide
1996 Subaru Outback(daily beater)
!992 T-Bird Super Coupe(yet, another project)
1995 GMC Suburban(will be for sale, soon)
1995 Dodge 3500 Club Cab(Cummins 12V)
2001 Freightliner(Cummins Powered Money Maker)
72LoBurb is offline   Reply With Quote
Old 03-10-2008, 07:59 AM   #3
c10hevy
c10hevy's Avatar
my fuel tank is now under my bed, a little better weight distribution. is weight distribution the biggest obstacle in these truck? I read somewhere that the rear trailing arms are the same that nascar used in their cars in the early 70's...so i was thinking that this truck should be able to handle with the best fullsize 4000lb vehicles out there. And with the multitude of aftermarket suspension components I would think you could get a truck that is a lot of fun around a track other than a 1/4 mile. The 1.02 lateral i know is high aspirations, but what do you think is possible with a little bit of money and know how?
Old 03-10-2008, 09:48 AM   #4
SCOTI
SCOTI's Avatar
Stock gas tank location isn't really a prob on these trucks but shifting the weight bias definitely wouldn't hurt overall.
GM truck trailing-arm suspensions are still used by NASCAR today. Why? Because that's the rules. The suspensions are simple & easy to regulate which makes it easier on the racing sanction. Do they work? Yes, and quite well. They work good enough & are stable enough that NASCAR will let people w/no racing experience get behind the wheel & run around a track @ speeds around 150mph w/just a few hours of instruction. Is there a better suspension for handling? Yep, but it will cost you more.
Is the truck suspension adaptable for street/mild-track handling purposes? Yep w/some tweaks (spring rates, center-of-gravity changes, roll center adjustments) the truck arms can handle w/good consistency which is a great thing for novice track guy/gal.
1.0+ sustained lateral g's from a stock framed truck? I can't say w/certainty but I'd be willing to guess it would be an incredible feat if @ all possible. The right frame, suspension-tune, driver, & some really sticky tires..... maybe it can happen. Could it happen on a street/track, dual-purpose vehicle? Unlikely.
Could a 64-72 GM truck be tweaked to handle like late model cars? Sure . . .... & then you could haul a bunch of stuff around in the back when your done playing slot-cars. Sounds like a fun project!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-10-2008, 11:53 AM   #5
c10hevy
c10hevy's Avatar
So, in your opinion what would you recommend for an incredibly well handling 68 daily driver? I know that 1.0+ lateral is pretty impossible, but im looking for the ideal handling characteristics needed for these large truck to be able to hug the roads as well or better than a sports car designed to. I guess im curious how good can these trucks handle? I mean how good is the stuff out there?
Old 03-10-2008, 12:24 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Google Art Morrison Engineering. I think they have a frame/chassis that will do it...G-Force.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-10-2008, 06:01 PM   #7
Andy4639
Old member
Andy4639's Avatar
I'm no engineer by no means but for the rear end in these trucks you can move the shocks out further on the axle. Have the front of the trailing arms moved further out from the center of the truck.
A four link setup would be the best though I would think with a corvette rear end installed.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-10-2008, 08:45 PM   #8
SCOTI
SCOTI's Avatar
Is your goal to get close to 1g in a 68 truck that can still be used as a truck? If so, I see air in your future. Whether it's bags swapped in place of coils completely, or just helper bags within the coils. I guess to help most effectively, we need to know your budget. What is your realistic goal to spend on this project?
As was suggested, AME offers some incredible frame/suspension set-ups. My friends can build stuff from scratch but have used AME's stuff on several vehicles. The downside is the cost involved since it's usually out of budget for daily driver type builds.
The stock stuff can work well though. Swap in a Porterbuilt Streetrods 'Dropmember' & you get lower center of gravity w/updated R&P steering w/o having to use dropped spindles which are notorious for compromising 'bumpsteer' in their effort to get the vehicle lower. If there's a downside to the Dropmember, it's that it's only available for air suspension.
If sticking w/the OE parts, some urethane bushings, a large sway-bar, & decent brakes will help too. Help us out w/your budget & everyone can offer suggestions that are better aligned w/your goals & finances.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-10-2008, 09:35 PM   #9
Frizzle Fry
Frizzle Fry's Avatar
Drop spindles do not cause bumpsteer. If anything they help avoid it by leaving the arm/tie-rod goemetry stock.
There's no reason you couldn't run coilovers with the shockwave dropmember.
Frizzle Fry is offline   Reply With Quote
Old 03-10-2008, 09:37 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Custom tube frame,engine setback, and suspension froma Z06 might start you in the right direction.Use some fiberglas parts to lighten it some more and move as much weight to the rear as possible.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-10-2008, 10:20 PM   #11
c10hevy
c10hevy's Avatar
First off thanks for all the input. And no , i dont have the budget for custom tube chassis and corvette parts, let alone the know it all to put it all together. my budget realistically right now is probably around $3000, give or take, for suspension alone, front and rear.
Call me old school, but i was thinking that coilovers instead of bags, bags seem to be synonymous laying frame, not pullin g's.
How could I use a four link with an independent rear axle?
NEW IDEA: im gonna look up prices for the corvette rear transaxle. Then i could move the tranny to just in front of the rear axle, shifting weight back, and getting a six speed. Has this been done before?
Old 03-10-2008, 10:43 PM   #12
c10hevy
c10hevy's Avatar
So i looked at Mr. Frizzle's 61 c5 and have decided that although ambitious, not realistic for me. btw Frizzle, does that beautiful Frankenstein drive? how does it handle?
Old 03-10-2008, 10:50 PM   #13
Andy4639
Old member
Andy4639's Avatar
Here are some good reads
http://www.customclassictrucks.com/h...uck/index.html
http://www.rodandcustommagazine.com/...ion/index.html
4 days left at $1000.00
http://cgi.ebay.com/ebaymotors/67-co...em220209698979
Old 03-10-2008, 11:03 PM   #14
SCOTI
SCOTI's Avatar
True.... That's why I said 'compromises' bumpsteer. Meaning the main objective of drop-spindles is to get the truck lower, not eliminate bumpsteer. If there's bumpsteer there (a/g body GM vehicles suffer this is from the factory), it prob won't get better & bumpsteer will have much to do w/that lofty 1g goal.
The coil-over idea is a great idea, I just didn't include that scenario until there was a budget thrown on the table.
As for bags being "synonymous" w/laying frame, check out AirRide Tech's road course activity @ many of the GoodGuys events. They're pushing to change that outdated logic that air is only for draggin frame by developing kits that offer lower ride heights, are adjustable, & ride better that typical dropped spring applications when compared model for model of vehicle. Some of the fastest cars around the road courses they help set-up are 60's muscle cars on airbags (as fast or faster than late model f-bodies or vettes).
It's the overall packages they offer that work well & make the vehicle handle better.
my budget realistically right now is probably around $3000, give or take, for suspension alone, front and rear. NEW IDEA: im gonna look up prices for the corvette rear transaxle. Then i could move the tranny to just in front of the rear axle, shifting weight back, and getting a six speed. Has this been done before?
A C5/6 transaxle IRS for under $3K..... not likely but entirely possible. Frizzle Fry has done just that on his project 61 short-step. As you've seen, there's alot involved.
Never got an answer to this one . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-13-2008, 11:32 PM   #15
Ackattack
Ackattack's Avatar
In my time racing, I think the most overlooked part by newbies is tires. Its easy to throw money at parts, but some people are reluctant to buy good tires. Also, imo, for racing any street tire is inferior to a race tire. There are just too many comprimises for a street tire.
That being said, 1.02g's for a truck is a VERY high bar to get to. I think a more reasonable goal would be around .90 - .92g's. I believe this is about where the Ford Lightnings are from the factory and should be acheivable in trucks like ours. My goal for my truck is to be able to out do a Ford Lightning in all catagories (accelleration, handling, braking).
Ackattack is offline   Reply With Quote
Old 03-14-2008, 12:37 AM   #16
67ChevyRedneck
67ChevyRedneck's Avatar
Z06 vette, Lamborghini, and viper are in the 1.0 to 1.1g range....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-14-2008, 06:01 AM   #17
71tahoe
71tahoe's Avatar
Somebody (Road and Track, Hotrod, Motor Trend...) got 1+ g from a 3000 lb G-body back in the late 80's or early 90s. I don't see why a 4000 lb truck couldn't approach 1g. It would definitely need some weight redistribution to the back and a lower CG. Aluminum goodies under the hood will shed a few pounds up front too.
71tahoe is offline   Reply With Quote
Old 03-14-2008, 07:20 AM   #18
TierAngst
I've seen people hit a full g with a 4000+ lb b-body. I know they have much better weight distro than a truck but I think with the right combo you could hit a .9+ no problem. As mentioned though tires are key.
TierAngst is offline   Reply With Quote
Old 03-14-2008, 08:24 AM   #19
72Levi
Active Member
72Levi's Avatar
My CTS-V can do a 1.0g it even has the gauge to prove it. Very tough to do it in our trucks.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum
2004 FORD FX4 SuperCrew
2005 CTS-V 12 sec family car
2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it!
72Levi is offline   Reply With Quote
