03-11-2008, 04:06 AM | #1 |
custom fuel filler hosea
probably going to mount my fuel filler behind the side marker light or weld in a side door from a later model. question is whatever i do it wont line up with a stock style rubber hose, where do I get the hose to go from my filler neck to the tank? thank you
03-11-2008, 05:50 AM | #2 |
Re: custom fuel filler hosea
i made the majority of mine with muffler pipe and bought a foot of filler hose at o'rielys. it was $17 a foot so plan it well
common sense isn't so common anymore |
03-11-2008, 06:18 AM | #3 |
Retired Air Force Veteran
I'm in the process of doing this. The following mod is done by using a later model (1997+up) S-10 Fuel Neck and same years S-10 gas door for the hinge.
If using the Poly Blazer tank, you should be able to use either driver or passenger side. I am using the driver side marker light. Many board members have refered to Tennmans setup for this modification. He also uses the drivers side. Here is his link for a step by step how-to of this mod. Thanks to board member jorgensensc for posting this: http://67-72chevytrucks.com/vboard/s...ad.php?t=77104 I think your inlet on your tank is 1 1/4 inch and the S-10 fuel neck is 2 inch. Here's how I reduced my Fuel neck. 2 inch reducer to 1 1/2 inch then 1 1/2 inch to 1 1/4 inch Now use 1 1/4 inch fuel line between to tank and fuel neck. Here's a pic of the copper hardware I'm using: I am not finished yet so I do not have any pics yet. PS That hole in the back of the d/s fender has been filled Good Luck Harry If you have questions, PM your number.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
03-11-2008, 11:17 AM | #4 |
Out of the carpool lane.
Harry, check to be sure that copper doesn't corrode when using 10% or higher ethanol gasoline. IIRC, it does and could cause problems for you.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
03-23-2008, 10:43 PM | #5 |
[QUOTE=myoldchevytruck;2619801]I'm in the process of doing this. The following mod is done by using a later model (1997+up) S-10 Fuel Neck and same years S-10 gas door for the hinge.
If using the Poly Blazer tank, you should be able to use either driver or passenger side. I am using the driver side marker light. Many board members have refered to Tennmans setup for this modification. He also uses the drivers side. Here is his link for a step by step how-to of this mod. Thanks to board member jorgensensc for posting this: http://67-72chevytrucks.com/vboard/s...ad.php?t=77104 Linky no worky |
03-23-2008, 11:48 PM | #6 |
Fishingjred,
Try this link on the fuel filler mod http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
03-24-2008, 02:42 AM | #7 |
Thanks, much better.
