03-12-2008, 08:40 PM | #1 |
Brake line question
Is it ok to use copper tubing as a replacement or does it have to be steel? I have some copper tub laying around and thought i better ask the pros about this one. Is it to soft to handle the pressure?
03-12-2008, 08:46 PM | #2 |
Robert Olson Transport
Re: Brake line question
i was told it wasnt any good for pressure and is too soft and will get damaged easy . steel is available cheap i just bought two pieces and a union for my kids truck and it only cost me $10 to go behind the cab to almost by the rear wheels
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
03-12-2008, 09:34 PM | #3 |
yes it will split fairly easy.
03-12-2008, 10:06 PM | #4 |
Agreed. Copper is a big no-no.
03-13-2008, 08:35 AM | #5 |
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
03-13-2008, 03:15 PM | #6 |
Not a good plan then
03-13-2008, 04:08 PM | #7 |
One shot, one kill.
Black: As stated by others copper is an accident waiting to happen, so don't use it. It has been my expirence that once one line goes, others will follow until you have replaced them all. This is especially true if you use "bulk" replacement line, because (A) it's a wee bit softer and (B) it's not as well coated as factory lines.
After replaceing mine several times I got a set of stainless steel ones and re-did the whole truck and switched to DOT 5 silicone fluid because it isn't water soluable, lubricates better and stands up to lots more heat. Go to "Classictube.com" and take a look around. A little pricey, but these lines are good, real good. You can't tell the difference between them and factory and they fit like a glove. Only downside is price (mine were about $250.00 American) and turn around time (about 6 weeks). I thought about it and figure if I have to spend 3 or 4 hours replaceing lines that have blown out at a most inopportune time, I've made my money back. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
03-13-2008, 05:42 PM | #8 |
Great information Jim! Ive replaced every brake line other then the front to rear line, i was more curious whether or not copper was ok to use in this application but everyone has stated its not the smartest idea, i had to ask.
Ive seen people use Aluminum tubing on there brakes before and Aluminum is soft thats more of the reasoning to my copper tub question.
03-15-2008, 08:51 PM | #9 |
I found this page where the guy is using a compression fitting to union the old and new line together, i thought this was also a no no ??
http://volksweb.relitech.com/brakeln.htm
03-15-2008, 08:54 PM | #10 |
I picked up all my new lines and fittings today, my only issue is connecting the old line to the new because of the double flaring i have to do to my old line, i have a flaring tool but im not sure on the technique any tips or pics would be of great help.
03-16-2008, 12:22 AM | #11 |
Try this website.
- Greg |
03-16-2008, 02:02 AM | #12 |
Great info on that site.
Thankyou
03-17-2008, 02:40 AM | #13 |
The brake job went well! thanks for the tips everyone!
