Old 01-22-2003, 07:25 PM   #1
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
Air Bag Question...
What is the lowest part on the truck if you use bags? Does the gas tank have to be relocated? What about the headders/exhaust? Not like I'll be able to afford the swap. I'm just dreaming.....
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 01-22-2003, 07:36 PM   #2
ocbaud
Garage Queen Material
lowest part on my truck with a 4/6 drop is my headers, so it will be the same with bags if you have full lengh ones.
ocbaud is offline   Reply With Quote
Old 01-22-2003, 08:30 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
On our trucks, the Y-pipe is first to make contact with the road (Talking about a factory-like setup now). The front cross-member and oil pan are also very low. The gas tanks don't need to be relocated in many cases.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 01-23-2003, 03:19 PM   #4
Izzy
Trucker.
Izzy's Avatar
Your tank will be about 3/4" off the ground once the control arms, y pipe and the tranny crossmember lay out. They will be higher if you have a normal bolt in notch.
Here's what my setup looks like laid out. The oil pan is no concern.
Izzy is offline   Reply With Quote
Old 01-23-2003, 04:22 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
What Izzy said... Lowest part on the crossmember will be the lower control arm mounts... Here is the front of mine layed out.....stock spindles
http://www.captkaoscustoms.com/images/bagged3.jpg
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-23-2003, 06:39 PM   #6
Izzy
Trucker.
Izzy's Avatar
I lay out about 35 psi so I need to get that lifted crossmember soon. What's the soonest you think you could have one done??
Old 01-23-2003, 07:15 PM   #7
Captkaos
Captkaos's Avatar
Well, I have located a donor for one. It took a weekend to get it mine chopped. Once I get it out of the truck, it should take about 2 days. Are you wanting it finished up with the grinding, or just welded?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-23-2003, 07:21 PM   #8
Captkaos
Captkaos's Avatar
Wasn't Ryan (low 84) wanting the first one?
I will have to find another one though, I guess I could sell mine if I have to... I have one drilled for bags already and could cut it for me.....
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-24-2003, 07:06 PM   #9
Izzy
Trucker.
Izzy's Avatar
Just welded is fine. I could grind down the welds and clean it up.
