03-15-2008, 09:41 PM | #1 |
banging noise
This is a goofy one. For the last couple of months, while driving we've been hearing this noise that sounds like a loud bang on a metal garbage can. The recently, when parked in the garage, out of the blue I will hear it again.
Did the same thing last night. Pulled the truck into the garage for a wash, about five minutes later, bang. Sounds ilke it's coming from behind the cab under the bed someplace. Gas tank?? It's a 2000 Silverado 1500. Z71. 180,000 miles. |
03-16-2008, 06:49 PM | #2 |
Re: banging noise
Catalytic convertor, maybe
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
03-16-2008, 08:58 PM | #3 |
Re: banging noise
The cat was a thought also, but from what? Pressure? It's just wierd when the truck is parked in the garage not running and then five minutes later....bang. LIke someone is under the truck with a hammer.
03-26-2008, 06:46 AM | #4 |
Re: banging noise
mabey the honney comb is loose in the cat and moves around with the expanding and contracting of the metal ?
ΜΟΛΩΝ ΛΑΒΕ |
03-26-2008, 07:21 AM | #5 |
He's got mean nasty FANGS!
Re: banging noise
Muffler heat shield most likely, take a look at it for broken spot welds. The spot welds break because the metal the muffler and the heat shield are made out of expand and contract at different rates... GMs fix and the only thing that does work is installed a long worm gear clamp over the spot welds to help hold it in place or to cut off the shield and clamp a new one on.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
