03-16-2008, 03:14 AM | #26 |
64-66 CHEVY JUNKIE
Re: Front disk brakes ( with pics)
Thanks salazar44, I also have the brake booster, MC and braket from the 72.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
03-16-2008, 03:17 AM | #27 | |
64-66 CHEVY JUNKIE
03-16-2008, 03:25 AM | #28 |
64-66 CHEVY JUNKIE
Thanks TimE Chad, and tony, badriand Thanks for the good words now back to that cold bud light. (LOL).
03-16-2008, 04:41 AM | #29 |
looks real good man!
03-17-2008, 09:17 AM | #30 |
Looks good, wouldn't mind putting power disc brakes on the front of my '63.
03-18-2008, 11:50 PM | #31 |
64-66 CHEVY JUNKIE
Thanks 1974K5 and Cman, Its supporting words like that that keep us all going with are truck (60-66) projects.
03-19-2008, 12:55 AM | #32 |
1962 C-10
Nice work! Looks awesome. Great pics....
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
03-19-2008, 10:02 PM | #33 |
Under Construction
looking good, now i need to look for 2 donor trucks, one for the son's 67 and one my inlaws 65.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-19-2008, 10:08 PM | #34 |
i think im just gonna swap out the whole front crossmember off a 87 burban over to my 63! i dont know what im gonna do with the rest of the burban though????
03-20-2008, 12:04 AM | #35 |
Hey Y'all!!
Scavenge any part that you can use or sell and haul what's left to the crusher. One of the local crushers is paying $7.50/100 in my area. Your area could be a little more or a little less. That way you can buy more parts for your toys!
04-03-2008, 12:25 AM | #36 |
64-66 CHEVY JUNKIE
Well today i installed my power brake booster mc and prop valve. I drilled 4 holes and mounted the braket in the spot where the old one was. when i had finished the brake rod was 1 1/2 inch to short to the brake paddle, ill take both rods to work with me and cut off 1 3/4 and weld it to the 72 rod.[IMG][IMG][IMG][IMG][IMG][/IMG][/IMG][/IMG][/IMG][/IMG]
04-03-2008, 12:27 AM | #37 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
04-03-2008, 12:27 AM | #38 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
04-03-2008, 12:28 AM | #39 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
04-03-2008, 12:29 AM | #40 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
04-03-2008, 12:29 AM | #41 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
04-03-2008, 12:30 AM | #42 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
04-03-2008, 12:59 AM | #43 | |
sorry for the jack, your truck is looking sweet Gulf!!
CHEVY ONLY |
04-03-2008, 01:23 AM | #44 |
Hey Y'all!!
04-03-2008, 09:24 PM | #45 |
Registered.........
[QUOTE=gulfcoast66;2658018]Well today I installed my power brake booster mc and prop valve. When I had finished the brake rod was 1 1/2 inch to short to the brake paddle,I'll take both rods to work with me and cut off 1 3/4 and weld it to the 72 rod.
I ran into the same problem with the brake rod coming up short when I put power discs onto my 1966 C10. Instead of cutting and welding, I sourced the end adjustable piece off of a newer truck (my 1975 C10 donor vehicle) since it was 1 3/4" longer than the factory 1969 booster bracket adjuster rod. All I needed to do was drill out the factory threads in the newer piece to enlarge the hole then re-tap the threads to fit the rod threads on the booster bracket. All in all the whole process took about 10 minutes and worked perfectly. Now, I'm not trying to hijack this thread, just offering a different solution to the same problem. Best of luck on your build - Pete
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
04-04-2008, 04:14 PM | #46 |
64-66 CHEVY JUNKIE
Thanks Wildone that sounds like a really good thing to do,So ill try that!
