Old 03-16-2008, 07:51 AM   #1
Locutus
Locutus's Avatar
Torquing the head bolts
I know that when you torque the head bolts that you should put a little oil on under the head of the bolt, but what about the threads? Will it affect the sealer they put on the bolts that go into the water jackets? Just want to make sure I do this right the first time don't want to have to do it twice
Michael
Locutus is offline   Reply With Quote
Old 03-16-2008, 08:13 AM   #2
tx71smallblock
tx71smallblock's Avatar
Re: Torquing the head bolts
i dont believe it mess with them, just remember to torque them in the right order and in steps.
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 03-16-2008, 08:51 AM   #3
Jim_PA
The reason for oiling under the head of the bolt is so you don't gall the surface of the head when torquing.
Jim_PA is offline   Reply With Quote
Old 03-16-2008, 06:04 PM   #4
LONGHAIR
By they, are you refering to some kind of factory applied stuff on aftermarket bolts? You really need to be sure to use a good liquid sealer. The bolts will leak if you don't. (ask me how I know)
LONGHAIR is offline   Reply With Quote
Old 03-16-2008, 08:30 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
If you apply a good liquid type sealant on the waterjacket related bolts, that is all that you need on them. The sealer has liquid base will lube the threads as necessary to do your torque settings. The oil on the others needs to be minimal, so that you don't fill the bottoms of the bolt holes (if they are a blind hole )and cause a possible crack in your block. All you wnat is to get the appropriate torque settings and then you are done.
Old 03-16-2008, 08:39 PM   #6
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
X2.
mtndewmaniac66 is offline   Reply With Quote
