Old 03-18-2008, 01:17 AM   #1
Cody chance
lowering and conversion questions
i have a 72 C20. I am wanting to convert it over to 5 lug and drop it with air bags. But have a hidden hitch to be able to tow when needed. Is it best to get a 1/2 ton axle for the rear and convert the front end over ass well. or should i go with the 5 lug conversion spindels and axle shaft conversion in the rear?
Cody chance is offline   Reply With Quote
Old 03-18-2008, 04:51 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering and conversion questions
Conversion spindles and a 5-lug 1/2 ton rearend will do it. (71-72,... or a 67-70 6-lug with new 5-lug conversion axles) You won't be able to swap JUST axles into your original housing,... since your 3/4 ton rearend is completely different. Then use all the the normal 1/2 ton bag stuff. Good luck. Post some pics if you get a chance.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 04-16-2008, 06:30 PM   #3
Charlesdur
Charlesdur's Avatar
I am doing the same thing sort of, but trying to keep my 8 lug set up on my 1971 3/4 ton. I found some cool rims from ION and MKG and now trying to figure out how to do a 4/6 drop. I can find the rear leaf springs for a 6 inch drop, but wondering if I can use the front coil srpings with a 4 inch drop out of a C10. I have a bagged 1966 tbird so my wife will shoot me if I drop that kind of cash for this truck also.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Charlesdur is offline   Reply With Quote
