Old 03-18-2008, 03:07 AM   #1
Lated
Lated's Avatar
Rear suspension help
I recently lowered my 70 c10 4" in the back (and an unknown amount in the front but that's a story for another day). I've put new tires all around and had the front end aligned since I lowered it. The truck tracks fine going straight but when I go around a right turn of decent length (like an on ramp) at about 35 miles an hour the back end feels like it floats around the corner. I say floats because it feels just like the rear is sliding but the tires aren't losing their grip but it definetly isn't tracking with the front. I've only noticed it turning to the right but I can't remember making any similar turns to the left so it could do it in both directions. I installed an adjustable panhard bar when I lowered it and I thought I had it centered but now I'm not sure. Could the panhard bar being out of adjustment be causing this, and if so what is the best way to measure to make sure it is centered under the truck. Any other ideas of what might be making this happen? I have a rear sway bar that I want to put on but I want to get this fixed first. (This pic reminds me I still need to get the correct length bolts for my diff cover so I can get rid of the extra washers)
Dave
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 03-18-2008, 04:00 AM   #2
cdowns
cdowns's Avatar
Re: Rear suspension help
easy way to measure for center is from the inside of the tire to the frame rail should be the same on each side/when lowering did you check the trailing arm bushings for wear?
Old 03-18-2008, 04:35 AM   #3
neonlarry
neonlarry's Avatar
When you had the alignment done did you have a 4 wheel or just the front?
Also it looks like you need some shock relocator mounts for your rear shocks, they are leaning over way too far to be effective.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-18-2008, 04:56 AM   #4
Lated
Lated's Avatar
The bushings weren't horrible but I probably should have gone ahead and replaced them. I couldn't get the bolts off and didn't want to make yet another trip to the hardware store for new bolts so I didn't get them changed although I do have a pair laying around.
I don't remember if it was a 2 or 4 wheel alignment, I'll have to dig up the invoice to check. I didn't know the angle of the shocks made that big a difference. I had originally planned on relocating them but due to budget restraints I decided not to. Would I have to get different length shocks to go along to go along with the relocator? It has drop shocks on it now.
Thanks for the help guys, Dave
Old 03-18-2008, 05:21 AM   #5
neonlarry
neonlarry's Avatar
If you have drop shocks now they will work fine. And the angle does make a difference.
Also have the wife or a friend drive your truck and drive along behind it and make sure it looks like its tracking straight.
