Old 03-21-2008, 12:20 AM   #1
trebeck
trebeck's Avatar
ART Control Arms and Sway bar - Tie Rod Issue?
Hopefully someone has a similar setup and can tell me if I have an issue. I'm concerned whether the tie rod will clear the top of the sway bar, looks awfully close. Something seems goofy with how high the sway bar attaches to the spindle. Sorry, this is the best pic i had:
trebeck is offline   Reply With Quote
Old 03-21-2008, 12:39 AM   #2
trebeck
trebeck's Avatar
Re: ART Control Arms and Sway bar - Tie Rod Issue?
I was able to find a different pic angle...arrow pointing to top of sway bar end link.
Old 03-21-2008, 06:38 AM   #3
shifty
Questionable
shifty's Avatar
I think you meant how high the swaybar attaches to the lower control arm? Either way, I see clearly what you're saying, and being that I'm running the same darn setup, I'm interested also
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-21-2008, 07:31 AM   #4
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Can I ask you to try something??
Can you push the back of the upper a frame in towards the frame and leave the frt part of the a frame left pulled out?? What I am trying to help you see is IF your mock up right now had more caster (upper a frame swept rearward) if you would have more clearance??
The first picture I see tells me if your spindle were laid back more instead of leaning forward it would bring the tie rod mount at the spindle UP more giving more clearance.
This is just a test to see if you gain more room with more caster.
NOTE.
Pull the frt of the upper a frame out as far as possible and push the rear in as far as possible and lets see how much room you gain.I know its not gonna be dramatic but you might gain some.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-21-2008, 05:23 PM   #5
stunna
i was told by ART that if you order their control arms and bags for the front, the factory swaybar will not work. they make a sway bar that works with the setup. hope this helps
stunna is offline   Reply With Quote
Old 03-21-2008, 06:18 PM   #6
SCOTI
SCOTI's Avatar
That's ART's sway bar ("muscle-bar") in the posted pics.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-21-2008, 06:48 PM   #7
trebeck
trebeck's Avatar
NOTE.
I believe I'm following you, I'll give it a shot this evening slammed1 and let you know how it goes, thanks.
Old 03-21-2008, 06:49 PM   #8
trebeck
trebeck's Avatar
Thanks SCOTI. Yes that is ART's sway bar.
Old 03-22-2008, 01:35 AM   #9
shifty
Questionable
shifty's Avatar
Damnitall, retrospect is a MFer. I just went to the junkyard and bought two swaybars and ordered bushings to boot. More wasted money!!
Old 03-22-2008, 03:13 AM   #10
pcmcobra
pcmcobra's Avatar
lol
art even tells you the stock swaybar will not work on their website...
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 03-22-2008, 06:08 AM   #11
shifty
Questionable
shifty's Avatar
i didn't read it! i think i actually got the swaybars before i got the arms, actually.
Old 03-22-2008, 06:10 AM   #12
trebeck
trebeck's Avatar
Ok slammed1, I gave it a shot, it bought me a little bit of clearance. Also, I noticed from another pic on the site that the tie rod comes in quite steep to the spindle, so I think I'm probably ok.
I'm still a little concerned with how the end of the sway bar hooks into the end link (doesn't fit flat, meets at around 30 degrees)...so I'd still like to see some pics of how similar setups work. Anyone?
Old 03-22-2008, 08:05 AM   #13
Shane
Shane's Avatar
so sell me the bushings and brackets ...
Shane is offline   Reply With Quote
Old 03-22-2008, 08:45 PM   #14
shifty
Questionable
shifty's Avatar
i would, but selling those alone i'd lose money I bought these (x4), $24, brackets and bushings.
i think i will end up selling both bars, $45 shipped w/OEM brackets but no bushings, $65 shipped with new aftermarket brackets and bushings.
oh, and a bump for other pics of ART setups.
