Old 03-21-2008, 01:40 AM   #1
Farmstore34
Farmstore34's Avatar
Question Posi rear axle question
Hey all,
I'm not 100% sure, but I think the positrac quit working in my truck. Its a 1972 K20, 350, 4 speed, and the original rear axle (GM Corporate?). From what I can tell only the right rear is spinning while going forward. Are there replaceable clutches inside? Thanks,
Colby.
Farmstore34 is offline   Reply With Quote
Old 03-21-2008, 02:59 AM   #2
Re: Posi rear axle question
No clutches at all.It would be a locker,not a posi,if it`s factory.Does the right side spin all the time,like a live axle?(go cart)
Old 03-21-2008, 06:53 AM   #3
Farmstore34
yes it seems to be working just like a standard axle. I think the left side kicks in occasionally but it is mostly being driven by the right side.
Old 03-21-2008, 07:02 AM   #4
texanidiot25
Eat My Rust
texanidiot25's Avatar
Jack up the rear end off the ground. And put the trans in N.
Spin one tire. If they both spin together and spin the driveshaft, the posi is working (in theory). If the other tire spins in the opposite direction, no posi action.
Either that, or jack (no stands) the passenger side tire off the ground, leaving the drives side on the ground. Put it into gear, and just let out the brake slowly. If the car starts to pull the jack with it, posi is good. If not, the tire in the air will just spin along. Sorta the more dangerous way, but the for sure way.
texanidiot25 is offline   Reply With Quote
Old 03-21-2008, 07:05 AM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
That is exactly what a posi does when the clutches wear out. It acts just like an open rear.
I just sent my carrier to Randy's Ring & Pinion and had them replace the clutch pack. It is tight now and even chirps the inside tire on corners, if you get on it.
PICKMUP is offline   Reply With Quote
Old 03-21-2008, 07:20 AM   #6
slammed1
1972 Chevrolet SWB
slammed1's Avatar
It does sound as if your posi is toasted. Parts readily available and unless your confident in your tools and work,I would have another person build it if needed.I had one in a 67 Impala get week and I could jack it up and rotate one rear wheel with my hand and the other wheel would spin completely opposite,just like an open but I knew 110% it was posi. The rear was rebuilt and is doing time in our Drag/Street Race 68 Impala now.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-21-2008, 07:53 AM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Here is one I pulled today. It spun like an open. There was no indication it was posi except listing on the SPID.
Old 03-21-2008, 08:29 AM   #8
67 cst swb
67 cst swb's Avatar
So, what does it cost to have a posi clutch pack replaced at Randy's?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 03-21-2008, 11:28 AM   #9
Mint68
Mint68's Avatar
I thought mine acted wierd when on jack stands, but on the ground it will leave two marks, and likes to slide either way in the snow. I was going to have mine rebuilt, but I was told it was a non rebuildable unit. Seems mine has cones not cluthes.
Mint68 is offline   Reply With Quote
Old 03-21-2008, 01:41 PM   #10
In the HO52,if that`s what you actually have,only the NoSpin/Detroit Locker came from factory.No clutches,not a posi.If it has a Dana60 it could have the PowerLock posi.
I had a problem with a NoSpin where only one wheel spun full-time,like a live axle.It was worse than an open rear because I got nothing from one side and full power all the time to the other.Believe me,if you`ve ever had this you`d realize how nice a bias open rear operates.With one wheel under power at all times you can`t back up a stone incline.It`s like a go cart.The only think I could figure was a weak side spring.But,I couldn`t see anything wrong.I just put another unit in that I had.
