ok first off i have a 69 chevy, got some what i was told 71 or 72 frt fenders and went to go put them on and well guess what i can not get them to go on to save my life some bolt will go on and some places need whole lot of force and still wont go on (mayb i should have kept the other crappy fenders on) will somone plz help me?
knuckle buster..
![]() Join Date: Oct 2007
Re: please sombody help
are they aftermarket?
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
![]() Join Date: Jul 2005
Front fenders fo 69-72 show the same part number for chevy. Looks like a different story for GMC . Not saying that is true to fit but , appears that is the case in the parts book I have here..Good luck
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
its all about the +6 inches
Something is wrong here, becouse all 67 - 72 fenders would bolt right on... anything 10 series to 30 series, c or k frame, blazer, burb, truck, long, short, step, fleet, cab and chassis... they are all the same and would bolt onto the truck with no problems.
The only thing that would throw you for a loop would be if it was a 67 or 68 chevy fender, or a GMC fender. And that would be minor trim issues, it'd still bolt right onto the truck |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
You have some issue that you are not seeing. Like Andy said all of the fenders from 67-72 Chevy or GMC will bolt on. Trim and grill issues would be the only problems then. Did you remove both fenders and inner fenders? Maybe the core support is leaning towar the cab? WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I have rebuilt alot of Chevy cars and trucks and one thing is common on all of them. That is they're all different if that makes any sense. Lining up fenders, doors, hood, cowl and quarter panels take alot of time and trial and error. Just when you think you have it a body line is off, a mrgin is off or weatherstripping makes a door or trunk not shut. I had a 70 Camaro repainted with the 3 piece rear spoiler and after I got it back and put the trunk weatherstripping on the trunk spoiler wouldn't line up with the spiler ends on the quarter panels. I had to adjust the trunk as high as it would go and slam the trunk and leave it for awhile and then open it and lower the latch. After a couple of months of this it finally lined up. Sorry for the ramble. Just keep doing it and you'll get it sooner or later. by the way after market parts always need extra time to install because of imperfections in tooling.
I have found its easier to loosen everything up then install the fenders then go back and line up and tighten up everything from the core support back.
no there not aftermarket and not 67-68 bcause of the blinker holes mayb gmc its just being a pain
would i have to use the 71-72 inner fenders and core support?
![]() ![]() Join Date: Jul 2002
You have to use the correct core support (69-72 Chevy), but the inners are the same.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 03-23-2008 at 01:46 AM. |
laying low
![]() Join Date: Mar 2001
The doors are already line up correctly right? If they're off the fenders won't line up good either. Your core support has to be at the right height also.
With the doors gapped right and the core support sitting up on it 's pads you should be able to lay a fender up in place and loosely install the bolts without a lot of pain. Minor shimming may be required.
passenger side lines up fine but the drivers side top lines up fine but the bottom dosnt
How bad were your old fenders? Could be if they were rusted pretty good, the bolt that mounts at the bottom is still there. It's a good sized bolt and would make your fender not able to line up. Or am I thinkin 73-87 trucks? Anyway, worth a look.
-Scott- |
I can only see a incorrect core support or slight imperfection in the front frame horns as being the culpert.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
