Old 03-25-2008, 02:41 AM   #1
suicide 63
burban body on truck frame
guys will a 66 burb body go on a 63 short frame? I found a burb on craiglist and I am going to look at it today and if it is in better shape than my truck body I would like to use my truck drive train which is nearly done.I will give you some stats on my frame
crossmember swap ,drop spindles, slam bags ,c-notch, power steering conversion,new 6 lug rotors,350 maf tpi 700r ,posi rear disk caprice rear end with adapters to 6 lug,made my own trailing arms and lowering blocks ,87 blazer tank it is baffled for fuel injection, stainless steel fuel lines and more.thats all i can think of right now
suicide 63 is offline   Reply With Quote
Old 03-25-2008, 03:43 AM   #2
greg64
greg64's Avatar
Re: burban body on truck frame
Yes, I think it probably would. The burb uses the 115" SWB. Anybody else know for sure?
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-25-2008, 05:11 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
Should just require some body mounts swapped over. Let's see it!
Frizzle Fry is offline   Reply With Quote
Old 03-25-2008, 06:06 AM   #4
suicide 63
heres the pics from the ad
he wants 2000 does not run door and body damage on passenger side its fixable though minamal rust in the normal areas.What do you guys think i know they are hard to find options are p/b p/s a/c all factory and custom trim and clam shell doors
Old 03-25-2008, 06:38 AM   #5
suicide 63
heres some pics of my frame
