Old 03-25-2008, 08:20 AM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Fuel Guage
Ok there is a wire from my gas tank that is connected to a terminal on the fuse block. When I pull this wire and turn on my ignition, it goes to full, when the wire is plugged back in, it goes to empty. Help!!! Gas cost too much not to know when im empty.
VDOG is offline   Reply With Quote
Old 03-25-2008, 05:32 PM   #2
haysonj
haysonj's Avatar
Re: Fuel Guage
I believe the problem will be with the sending unit in the tank. either the float has a hole in it and does not float anymore or the resistor is burned out. either way you will need to pull the sending unit out of the tank
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-25-2008, 09:57 PM   #3
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Fuel Guage
Thanks for the info, unless its a cheap part, then I will live with it until I change to a bed mounted tank.
Old 03-25-2008, 10:46 PM   #4
elektrik
Foolish Mortal
elektrik's Avatar
Re: Fuel Guage
Cheap is relative-LMC sells one for ~$50 which I thought was cheap (since you don't want used in this case LOL!)
elektrik is offline   Reply With Quote
Old 03-26-2008, 12:26 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel Guage
If it's the float, then it could be dirt cheap. You can afix anything that floats on the rod.. anything that wouldn't be eaten by the gas.
Old 03-26-2008, 07:57 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Fuel Guage
Thanks I will take it apart tomorrow.
