Old 03-25-2008, 01:56 PM   #1
jamon8
jamon8's Avatar
heat blowing cold
boy am I glad the temps are up here in S IL
all of a sudden my heat is blowing cold
any ideas
jamon8 is offline   Reply With Quote
Old 03-25-2008, 02:37 PM   #2
69rut
Re: heat blowing cold
Here are some ideas:
Heater core blocked, this could be internal or external
Fan motor not working, fan broken
Thermostat stuck open
Heater control valve closed
Cab duct work not in proper position
trailers are for boats
69rut is offline   Reply With Quote
Old 03-25-2008, 02:39 PM   #3
Low on coolant?
Old 03-25-2008, 03:50 PM   #4
lks dcvn
lks dcvn's Avatar
Just a guess, but there could be leaves, pine needles, rodents, etc. living in your heater box...
Mine works well enough in my beater, but I will be taking the cowl off - cleaning that stuff out (putting a fiberglass screen under the cowl opening) and putting it back on...
Then I will be removing the box under the hood and making sure that everything is clear (no junk in there) and then giving it another run...
I have been told that the heaters in these trucks sometimes work too well...
When I turn on my blower in the cab - I get an assortment of leaves, etc. that comes out of the ductwork (top of the dash and below) so I know that there is stuff in there...just hasn't been warm (and dry enough) to do it yet.
The other options are also valid.
Good luck.
lks dcvn is offline   Reply With Quote
Old 03-26-2008, 03:10 PM   #5
jamon8
jamon8's Avatar
thanks guys for the quick replies
all of a sudden the heat started to work yesterday
I am going to check the coolant level today and the cowl
