03-26-2008, 01:50 AM | #1 |
Smok'em Roast'em Shift'em
1981 Shortbed Stepside 2wd Build
I just got a 1981 Chevy Shortbed Stepside 2wd truck. I found it local in a marina. It's a 6 cyl truck but had a th350 and a 12 bolt non posi rear. The cab corners and rockers are rotted and the driverside floor has a hole in it. One of the previous owners patched the floor and tried to do body work to it and just caked on bondo wherever it was dented or rotted. Ive pretty much got everything out of the truck except the guage cluster. The bed is off and the whole nose is off and the motor is out. The frame was covered in about 1 inch of grease. A little degreaser did the job tho. The frame wasnt really rusty at all though and a little wire brusing cleaned it right up.
Not the best pics. I forgot to take pics before i stripped the truck. w.e Future Plans- Weld in cab corners and inner/outer rocker panels patch floor, 3/5 drop with spindles in the front and flip kit in the rear |
03-26-2008, 02:22 AM | #2 |
Re: 1981 Shortbed Stepside 2wd Build
Here is a slide show of the pics not the best but ill get more!
http://s299.photobucket.com/albums/m...view=slideshow |
03-26-2008, 04:42 AM | #3 |
what did you pay for it if you dont mind me asking.
2012 F150 SuperCrew 2011 GMC 1500 (COMPANY TRUCK) 1982 Chevy Blazer 2WD (Work in Progress) |
03-26-2008, 04:53 AM | #4 |
$1400 i think it was a little overpriced but i am only 16 and its my first truck i am building so i dont mind
03-26-2008, 08:23 AM | #5 |
Sb 400 club
Stick with it. nice stepper you got there and a 6 cylly too!!! Nothing is cooler then a cammed up sixer. Have fun with it.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
03-26-2008, 05:28 PM | #6 |
STILL PLAYS WITH TRUX
That's a good project you have there.
You have a plan and now you have to stick to it kid, And get it done and enjoy driving it. Good luck with it. |
03-27-2008, 03:53 AM | #7 |
I am going to put a cammed small block 350. Nothing big just something to sound good for now.
03-27-2008, 05:07 AM | #8 |
Tot Roddin'
Nice score!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-27-2008, 05:49 AM | #9 |
6.0 powered square
you have a good project on your hands
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
03-28-2008, 02:32 AM | #10 |
I ordered all my parts from Brothers Trucks. Everything is in my bedroom, just waiting for some warm weather!
03-28-2008, 06:55 AM | #11 |
1400 isnt bad at all i paid 3 grand for mine and pretty much just replaced everything that bolts up to the box on my stepside. Had to weld in new cab corners as well, they looked good when i first bought it but turned out the guy was a master with the bondo. But the truck is lookin good now and not a cancer victim anymore.
03-29-2008, 02:13 AM | #12 | |
03-29-2008, 02:48 AM | #13 |
1400 sounds like a great buy to me. good looking truck.
03-29-2008, 03:26 AM | #14 |
would rustoleum be good to paint the chassis or does it pay to buy chassis paint?(glossy black)
03-29-2008, 07:33 AM | #15 |
I used Tremclad paint which i think is the same as rustoleum down there and its worked for me on a few different vehicles it depends on your budget i guess, If you want to spend more on that thicker frame paint then that is cool but ill stick with my tried and true, Im sorry i dont have any pics of me doing the cab corners but im sure there is a thread on this site of someone doing it, Its quite easy just make sure you keep a nice straight edge between the two pieces so you dont get gaps between them before you weld them and just take them in place first to make sure everything lines up. After they are tacked do a short bead in between tacks and then let it cool so you dont warp the metal. Biggest thing i can say is Take your time doing it dont try to rush or it will go bad in a real hurry.
Im bolting all my new stepside pieces on tommorow and bolting the box back down to the bed and then im gonna start working on the cab and keep pushing forward in my battle with the rust monster !! |
03-29-2008, 08:21 AM | #16 |
6.0 powered square
after you dill with any rust, if theres a tractore supply in your area you can get there tractor paint for less than $40 a gallon with harder out the door, if you dont have a gun, the same stuff is in rattle can around $5, and if you have bare meatel spots you will need some sell etchin primer, which you might find in a auto parts store but its not cheap $20 for a rattle can for the good stuff
04-12-2008, 04:46 AM | #17 |
do you know the brand of the tractor paint to use. I went to a local tractor supply near my house upstate and they had all different brands. Are they all the same?
04-12-2008, 05:20 AM | #18 |
6.0 powered square
the brand is Valspar, black and green can
04-12-2008, 10:48 PM | #19 |
I saw that! Would you prefer to use that instead of rustoleum?
04-13-2008, 04:22 PM | #20 |
Spear and magic helmet!
Rustoleum has a hammered finish paint that looks pretty good on chassis and suspension parts. You might check into that if you get a chance.
04-13-2008, 07:24 PM | #21 |
Sb 400 club
If you can get tractor and implement paint it tends to last a bit longer then rustolium. At least that is my experience. Also to paint your frame and have it look close to factory try rustolium #7777.
05-06-2008, 05:38 AM | #22 |
05-06-2008, 06:07 AM | #23 |
Robert Olson Transport
lookin good im right down the southern state from ya in brooklyn any good car shows out that way in the summer?
my truck is rusting away i gotta do rockers and corners myself one of these years
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
05-06-2008, 09:52 PM | #24 |
Thanks, during the summer there are a lot of car shows. Every friday night there is one at Bellmore train station, this May 18th there is a car show/swap meet at the merrick fire dept race track, and there are others that ill let you know about.
05-07-2008, 02:00 PM | #25 |
Looks great! keep the pics coming
