03-26-2008, 06:15 PM | #1 |
Cowboy Up
Diamond plate flooring mold?
Heys, as you all know i am restorting a 1968 4wd 3/4 ton GMC. Do you know of anyone that was a Diamond Plate Flooring Mold, that people can buy and put in the truck? Trying to find some diamond plate but wow, that stuff is hard to find that i actually want and looking for. I found some at Fleet Farm but they are in small sheets. I know there is some many different opions with the flooring issue but won't hurt asking.
1971 chevy k10 *Under the Knife* Chris Cary |
03-26-2008, 08:42 PM | #2 |
Lemme show you something!!
Re: Diamond plate flooring mold?
I don't know of anyone who makes a diamond plate floor panel for our trucks. Are you looking to overlay or replace the existing floor? Either way you'll most likely need to fab it up from pieces. As far as finding the material is concerned- you might want to give Bellman-Melcor or Des Moines Steel, both in Des Moines, a call - they might be able to get you hooked up. I'm sure there are some suppliers in Minneapolis too.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") Last edited by Dingfodgy; 03-26-2008 at 08:43 PM. |
03-26-2008, 08:50 PM | #3 |
Des Moines is a little closer than Mpls is
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-27-2008, 12:09 AM | #4 |
Cowboy Up
sounds good, there is sheets of diamond plate at Fleet Farm but just wanted to see what there was... probably better to have someone that knows whats going on to do so. I am thinking about replacing it
03-27-2008, 12:18 AM | #5 |
Here's a place you can get 1/4" thick polished aluminum 36"x48" shipped free for $271... other sizes and materials available.
http://quickshipmetals.com/s-al-tread-250-36-48.html If you were going to put it on top, you could drop down to 1/8" at that size for $139.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- Last edited by TonyJohnson; 03-27-2008 at 12:21 AM. |
03-27-2008, 12:32 AM | #6 |
Here's what I did the plate comes in 4 ft and 5 ft wide sheets. I used stainless pop rivets to hold it down and after the truck was painted I had a LINE-X bed liner put in.
69 Chevy 4x4 383 Power |
03-27-2008, 01:05 AM | #7 |
C10 addict
Food for thought, if you are replacing your existing floor you will have to bolt in the aluminum diamond plate rather than weld it due to the large difference in melting points between aluminum or steal. You could braze them together, but I don't know the longevity of brazing.
03-27-2008, 01:20 AM | #8 |
no, ther is no way of welding/brazing aluminum to steel.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!! |
03-27-2008, 01:35 AM | #9 |
Are you talking aluminnum or steel?I don`t think you can get a piece wide enough for a 1pc. floor.At least not for a decent price.Do you just want to do the floor,over wheelhouses too,or sides and all?I go to a truck body place to get that stuff.They`ll sell cut to size,bend,or even fab if I need it.The place I go to is a truck hoist place.To get a piece cut and bent usually only costs their $25 minimum.I gave them a rusty Blazer tank skid plate and they made me a 5/16" aluminum diamond plate copy for barely more than the cost of material.Check those kind of places.Major cities have steel suppliers where you can buy stock.The truck hoist place will order in anything I want if they don`t have it.It`s a great resource.Usually I`ll just give them a drawing with dimensions and degree of bend.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-27-2008 at 01:38 AM. |
03-27-2008, 01:36 AM | #10 |
There used to be a kit for skinning the lower quarter panels on a Blazer with 1/4" diamond tread aluminum. It was called "Tuff-Skin" or 'Tuff-Hide' or something. Off Road Design [associated with the Colorado K5 site] was selling it, but when I checked last, it was no longer available.
I then thought of making my own panels, but the high cost of the aluminum killed that. One source of these type panels would be an aircraft surplus supply house. I have bought small pieces from a place in Tucson. [We have a lot of aviation-related activity here]. Their prices are a lot cheaper, but it's all subject to availability. One suggestion -- if you're rivetting aluminum to steel -- would be to use a good anti-rust primer on the steel side and Zinc Chromate primer on the aluminum side to minimize electrolytic bi-metal reaction.
03-28-2008, 05:50 PM | #11 |
Cowboy Up
ok sounds good, anyone know a website so i can contact them?
