Old 03-27-2008, 02:48 AM   #1
bdydrp97s10
bdydrp97s10's Avatar
what rearend do i have
i swapped the rearend n my 68 to a 5x5 pattern.. and it sits on coilsprings ..
i have no idea what year truck the rearend came out of though, any help
bdydrp97s10 is offline   Reply With Quote
Old 03-27-2008, 03:22 AM   #2
jlaird
jlaird's Avatar
Re: what rearend do i have
more info needed. got a pic?
jlaird is offline   Reply With Quote
Old 03-27-2008, 03:38 AM   #3
EyeH8the24
EyeH8the24's Avatar
there should be some numbers stamped into the axle tube ...think on the passenger side....those would help the gurus figure it out
EyeH8the24 is offline   Reply With Quote
Old 03-27-2008, 03:54 AM   #4
bagged81
Signals in the bumper.
bagged81's Avatar
Perhaps an early 70's Blazer, Chevelle or Nova?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 03-27-2008, 04:44 AM   #5
danielwetpaint
danielwetpaint's Avatar
A picture will help to quickly identify it.Impalas and caprices had coils,so did Chevelles and other GM's. Is it a 10 bolt or 12 bolt? Can we see the rear end cover?
Current ridesne owner GMC 1974 swb, 1986 Chevy lwb,chopped top '85 S-10,1948 Stylemaster rat rod,'2008 Honda Civ.Chopped top '46 dodge.
danielwetpaint is offline   Reply With Quote
Old 03-28-2008, 02:53 AM   #6
bdydrp97s10
ill try and get some pics friday.. i know it has a 306 gear in it because i pulled the cover and checked it.. and when i bought it the guy told me it came out of a truck?? thats all i know about it.. ill try to get some pics
Old 03-28-2008, 04:02 AM   #7
Shane
Shane's Avatar
i don't think 3:06 ratio was offered in the trucks ... maybe 3:08?
Shane is offline   Reply With Quote
Old 03-28-2008, 03:45 PM   #8
HotRodYJ
HotRodYJ's Avatar
71 and 72 Chevy's with disc brakes are 5 on 5 pattern from the factory. Chevy's had coil spring rear as an option. I've owned a 72 and a 71 that both where coil spring rear and 5 on 5 from the factory.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 03-31-2008, 03:37 AM   #9
bdydrp97s10
well the rearend is not disc brakes.. it drums but im assuming it is out of a 71 or 72
Old 03-31-2008, 03:42 AM   #10
bdydrp97s10
Old 04-02-2008, 01:01 AM   #11
bdydrp97s10
well th rearend is a 12 bolt, non posi. 306 gear, coilsprings,
and it measure 65 inches from flange to flange.. soes this help at all
Old 04-02-2008, 04:04 AM   #12
danielwetpaint
I had something to say but re thought.
Old 02-09-2009, 11:19 PM   #13
bdydrp97s10
any help.. still no answer on what rearend this is... the specs that o know are 2 posts above
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
Old 02-10-2009, 07:42 AM   #14
HotRodYJ
HotRodYJ's Avatar
My point is 71-72 trucks that came with disc brakes on the front from the factory are 5 lug trucks. The earlier trucks with drums up front are 6 lug trucks. Chevy stopped putting coil spring rearends in any truck in 72. Therefore, if your rear axle is a truck axle, 5 lug, and on coil springs it had to have come from a 71 or 72 Chevy that came factory with disc brakes up front.. This is the only trucks that came with this combination from the factory.
Old 02-12-2009, 05:42 PM   #15
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
I am with the other guys here.
There should be a set of numbers on the passenger side axle tube with numbers.
Find it!
Post it!
And lets see if someone here can help ya!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 02-15-2009, 12:52 AM   #16
67 cst swb
67 cst swb's Avatar
agreed... Only 71-72 GM trucks had trailing arm coil spring mount rearends with 5 on 5 bolt pattern....
Now,... on the top of the passenger side axle tube, there will be some letters and numbers stamped into the housing. If you can get me the 3-lettered code(only 70-72 had 3 letter codes, 69 & earlier had 2 letter codes) (example...THA, TRS, RHB, RRS, etc) from this location, I am holding a piece of paper that tells what that axle originally had in it for gears, depending on code may tell me exactly what year the axle is from... PM me if needed...
Anyone else that needs 67-72 axle code referenced, PM me... I have a chart, but 1967 to 1972 only.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
