Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-27-2008, 07:19 PM   #1
Blackstone
Blackstone's Avatar
Any hydraulic clutch gurus here?
I haven't seen the truck yet, but it's a '96, 2wd, 4-cyl with an internal slave cylinder.
The owner says he's been losing fluid, and needs to pump the pedal several times to get the truck into 1st gear. My first thought is that either the master or slave cylinder is leaking. I'm first going to check for leaks, but just in case I can't find one... Is there any way to determine which item has failed without actually spotting the leak? Would the system behave the same way regardless of which part is leaking?
Blackstone is offline   Reply With Quote
Old 03-28-2008, 04:15 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: Any hydraulic clutch gurus here?
sounds like air in the system. most likely from either the MC or SC. a 96 is probably due for a clutch so doing both cyl's would be the best bet. otherwise try doing the MC and a back-bleed.
68C15 is offline   Reply With Quote
Old 03-28-2008, 06:24 PM   #3
Blackstone
Blackstone's Avatar
Cool, thanks. I'll get a look at it... The owner just told me that he's been refilling the reservoir daily, so the leak should be easier to find than first feared.
