Old 03-27-2008, 07:34 PM   #1
andys70c10
rubber or cork valve cover gaskets
what do ya'll prefer & why? sb chevy.
andys70c10 is offline   Reply With Quote
Old 03-27-2008, 07:43 PM   #2
OrangeCrush1970
OrangeCrush1970's Avatar
Re: rubber or cork valve cover gaskets
Rubber, the cork will split if you mess up and crank the vc's down too much. Rubber just lasts longer.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 03-27-2008, 08:01 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I'm old shool, I like cork. It's hard to find them now though. I looked for ever for a cork trans pan gasket, finally went with rubber and it took me forever to get it to quit leaking. Snug the nuts up with cork and you can't go wrong.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-27-2008, 08:30 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
I like rubber, it lasts longer an seals better.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-27-2008, 08:44 PM   #5
tcb-1
Nothing to see here.....
tcb-1's Avatar
I like old school cork, but you do have to watch your torque values on the cover bolts. AND you must use spreaders!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-27-2008, 08:46 PM   #6
chevy72blu
chevy72blu's Avatar
I prefer cork as well, with a little gasket maker... Ive just had less of them get to leaking on me. I have not had any leaks without spreaders - the torque is the key. You need less than you think
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 03-27-2008, 09:17 PM   #7
andys70c10
do ya'll use gasket sealer with the rubbers?
Old 03-27-2008, 09:30 PM   #8
OrangeCrush1970
I still use RTV sealer w/ my rubber gaskets.
Rottenwood Garage
2 Tons of Fun
Old 03-27-2008, 09:34 PM   #9
chevguy7
chevguy7's Avatar
I have only used cork on mine, no leaks at all.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 03-27-2008, 09:47 PM   #10
Myself
I use Versa Chem OEM Grey Gasket Maker. No gaskets at all, and never have leaks.
Myself is offline   Reply With Quote
Old 03-27-2008, 10:17 PM   #11
hvychve
To The Levy
hvychve's Avatar
Rubber all the way, The cork gets hard and than loses its sealing abilty, has to be changed more often than rubber........
hvychve is offline   Reply With Quote
Old 03-27-2008, 10:37 PM   #12
Ole Blue 68
Ole Blue 68's Avatar
No contest, rubber.
I still use RTV with it and haven't had any problems.
Ole Blue 68 is offline   Reply With Quote
Old 03-28-2008, 12:33 AM   #13
70GMCer
70GMCer's Avatar
Cork with metal made in between. Costs more, but worth it.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-28-2008, 01:16 AM   #14
63 & 64 Bowties
and a few others
Use these (fabricated) and you'll never have to worry about torquing down too much again. This is what I have, except with the breather holes. The big advantage is even pressure all the way around the gasket face. High grade billet 6061 T5 aluminum. Very thick. plus, it kinda makes a SBC look like a BBC.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
Last edited by 63 & 64 Bowties; 03-28-2008 at 01:19 AM. Reason: felt like a peanut butter & jelly sandwich
63 & 64 Bowties is offline   Reply With Quote
Old 03-28-2008, 01:41 AM   #15
andys70c10
those are nice but a little out of my low buck budget, i think i'm going with rubber. Thanks for all the help
Old 03-28-2008, 02:16 AM   #16
corn
I like the rubber gaskets. Ive had good luck reusing them too.
corn is offline   Reply With Quote
Old 03-28-2008, 03:20 AM   #17
Mint68
Mint68's Avatar
Go rubber for the valve covers. Cork causes problems once you want to take them off for adjustments.
Mint68 is offline   Reply With Quote
Old 03-28-2008, 05:23 PM   #18
tim21391
tim21391's Avatar
i prefer cork...the motor shop put rubber gaskets on my valve cover and it only lated 10,000 miles and it leaked...i used this weatherstrip adhesive for a gasket maker and the weatherstrip adhesive and the cork go good together i havent had leaks yet...my old rubber gasket was cracked and everything....i got my cork set for like $13
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-28-2008, 06:03 PM   #19
68gmsee
Active Member
68gmsee's Avatar
I've used both but overall I prefer cork with rubber.
Rubber lasts longer but tends to leak- at least in some cases. Holds it's shape better.
Cork won't last as long since it tends to harden but, with proper torque, seals better. Tends to shrink some when dry.
I still use a thin layer of permatex gasket adhesive. Strictly to hold the gasket in place to the covers.
FYI: Something I read recently in Popular Mechanics... Silicone based sealers can contaminate oxygen sensors in newer vehicles. The chemicals are absorbed into the oil and in turn burned in the combustion chambers. Not sure if this is true.
68gmsee is offline   Reply With Quote
Old 03-28-2008, 06:24 PM   #20
faribran
have you ever had to remove the cork ones...??? "nuff said.
faribran is offline   Reply With Quote
Old 03-28-2008, 07:08 PM   #21
Ole Blue 68
x2
Old 03-28-2008, 07:46 PM   #22
420am
420am's Avatar
Check into the Fel-Pro PermaDryPlus gaskets. They're rubber with metal re-enforcement and they're actually reusable. I just put a set on my truck. They were $21 at O'Reily's.
420am is offline   Reply With Quote
