Old 03-28-2008, 06:17 AM   #1
ed2552
ed2552's Avatar
Truck Update! :metal:
Alright here's what i did this weekend on my 67 K10:
New Fuel Filters
New Battery
New Battery Cables
Bashed Starter W/ Ball Peen Hammer
A LOT of screwing around on trying to figure out why it wouldn't start
What i have now is a truck that runs and drives, but does not stop. I am going to get new drums, shoes and master cylinder at NAPA or Advance. My parking brake is shot, and is that just part of the drum? what is the deal with that? Also i need a rear brake line, where is the place to get that? I'm also going to replace the ginormous hubs and replace them with warn hubs or the like. Does anyone have any experience with these? Any other suggestions as to what to do or what else i should replace? Also, after 10 minutes of driving, my thermostat housing was 190 deg. F, i know that is not normal, there was also some coolant on the intake, should i replace all of the hoses and the thermostat? the housing i would replace at that time b/c it has some weird fittings on it and it is really nasty. I'm open to any other suggestions and comments.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-28-2008, 06:47 AM   #2
72lb4x4
Re: Truck Update! :metal:
Do you know these parts are bad, or are you just throwing money at it? I don't want to insult you but without info on why the parts are being replaced its hard to tell why.
A brake line on the axle tube to the wheel cylinder is easy enough to buy a straight one from the parts store and bend to fit.
Drums shouldn't have much to do with the E-brake.
Why replace the existing hubs? Just because they're big?
Have you pulled the drums, and checked the condition of the shoes, wheel cylinders, and drums?
If you need a brake line replace it, bleed the brakes and start from there.
Drum brakes aren't that good to start with and most braking is done by the front due to weight transfer. Start with the front.
Regarding hoses, chances are pretty good they could all stand to be replaced.
If you get an aftermarket inlet fitting (where the top hose goes), don't be too surprised if it isn't flat and leaks. Cheap auto parts are the norm these days. You might want to get one from a truck in the scrap yard. A lot of them are made of mystery metal and rot away.
Just a few opinions... Disregard as desired.
72lb4x4 is offline   Reply With Quote
Old 03-28-2008, 06:54 AM   #3
ed2552
ed2552's Avatar
Ok, the brakes suck, i have a cracked line on the frame somewhere, it just leaks out of the line constantly. I want to overhaul the brakes because i know they have been neglected, and i want to be able to safely drive it on the road and not kill someone. I want a clean slate and brakes to be able to stop in a decent distance. The master cylinder was re manned in like 92, it is all rusty and nasty.
Old 03-28-2008, 08:09 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
NAPA should have everything you need. I got new shoes, rear e-Brake cables, master cylinder, wheel cylinders and had the drums turned for my C-10 there. If you have one line leaking I would check them all very closely. Many times when you replace a leaking line another leak will pop up somewhere else.
LockDoc
Leon
Old 03-28-2008, 08:14 PM   #5
Cyclone44
Step Brother
Cyclone44's Avatar
LockDoc
Just don't ask how I know this is true...LOL
Cyclone44 is offline   Reply With Quote
Old 03-29-2008, 02:25 AM   #6
ed2552
ed2552's Avatar
yeah, I'm sure it is leaking, the M/c is bone dry in the rear res. every time i drive it.
Old 03-29-2008, 03:07 AM   #7
berencam
berencam's Avatar
dont forget just because the rear reserve in the master cylindar is bad doesn't mean the rear breaks need over hauled. If my memory serves the rear reserve on the master actually is for the front breaks.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 03-29-2008, 03:16 AM   #8
ed2552
ed2552's Avatar
There is a line leaking somewhere, i think it is the back, because there is a small puddle under the bed.
