Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-29-2008, 07:31 AM   #1
M1A1TankerTom
My Setup
Hey all, I have been slowly gathering the parts to build up my truck. Just got everything together thought I would throw at you all what I am running and see what you think.
1962 Chevy short wide bed pickup
Engine:
1969 396 big block
-Bored 030/Line bored
-TRW forged pistons (dome) 11.1
-Stage 4 rods
-Steel crank 10/10
-Chrome moly rings
-2 bolt main, ARP studded
-HP oil pump and pick up
-Isky Z-89 630 lift solid cam
-Roller rockers
-Square port heads cc-100.967
-Heads are fully pocket ported and polished
-Manly valves (severe duty)
-Cam button
-Felpro fire ring head gaskets
-Vic Jr air gap intake
-Carb shop 850 double pumper carb
-Belt driven
-Estimated 580 hp
Tranny:
Hughes TH400, summit part # hup-34-2, full manual valve body
Converter:
B&M holeshot torque converter, advertised stall 3,000 rpm, summit part # bmm-20413
Rear end:
12 bolt, posi, 4:10 gears
Tires:
Mickey Thompson ET Street Radials, 275/60/15's
So thats what I got right now, im not too sure what the weight of the truck is yet. What do you all think of this set up? Any guesses as to what she might be running in the 1/4 mile? Let me know what you think.
M1A1TankerTom is offline   Reply With Quote
Old 03-29-2008, 09:59 AM   #2
Super73
Super73's Avatar
Re: My Setup
If I had to guess I'd say low 12's to high 11's. Should be pretty sweet..
Super73 is offline   Reply With Quote
Old 03-29-2008, 04:19 PM   #3
RatPwrd72
RatPwrd72's Avatar
Re: My Setup
I'm gonna say traction will be a serious issue with that motor and short rear tire. We run that same cam in our 396 with more compression (12.5 to 1) and it hits really hard. My converter will flash to 5000 and with 5.38 gears and a 32x14x15 slick. Look a few posts down to see a video of my truck. BTW, I have a new best time of 10.87. Good Luck.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
