#26 |
67-72 Addict!
Re: too low?
I see no reason why the control arms would not work with the new springs. You should ask him what the specific issue was.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#27 |
Re: too low?
Your mechanic installed dropped LCA's without telling you and trust isn't an issue?
Wow, I wish I had your spirit of forgiveness. |
#28 |
Regular Confuser
Re: too low?
ill pull my stock front springs out of my donor truck and send them to you for your lowering springs..... ill send you mine first so you can get everything the way you like it, then after the swap, just shoot the shorter ones my way
#29 |
Re: too low?
Oh, I should probably add:
My gas tank is in the bed, hence the exhaust hanging below the frame. It's just a stock blazer tank, and it takes up the entirety of the space between the frame in the rear. |
#30 |
Re: too low?
that sounds good, actually. how much taller are they?
#31 |
Regular Confuser
Re: too low?
no idea bro.... if you really want them just give me the word and your mailing address and i will get out there and yank em
#32 |
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: too low?
I don't mean to screw up a potential deal here but if you are worried about driveability, I really think you should get rid of those lower control arms. If you look at how they are built, the ball joint mounting position is stepped up which puts the bottom of the LCA that much closer to the ground. From the pictures, it looks like you only have an inch or two of clearance below the LCA which will almost certainly cause you trouble. Also, it is a fabricated part... Do you know who built them? Are the welds going to hold? You're just asking for trouble if you leave those in there. Your spring are fine, get rid of the control arms.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
#33 |
Regular Confuser
Re: too low?
i agree, i was just trying to help the guy... swap those first, but if you are still set on swappin the springs lemme know
#34 | |
Re: too low?
Agree totally. Control arms don't "go bad." Find out what the issue is for your own peace of mind... consider finding a new mechanic also.
'84 M1008.. crawl.. ![]() 6.2 diesel/6" lift/4.56's '81 c10 swb.. cruise.. ![]() ls5.3/th350/20"billet/custom paint '92 eclipse gsx.. 11.6@124.. ![]() '06 cummins dodge.. tow..:couldnt afford a chevy club: |
#35 |
Re: too low?
it's pretty funny! your mechanic or another of his customers deemed this setup too low. hence the reason they are extra, but he thought it was a good idea to lower your truck that way.i dunno dude! you may need to do some soul searching on this one.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() Last edited by 69face; 03-29-2008 at 06:03 PM. Reason: typ |
#36 |
Re: too low?
Run a taller tire..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#37 | |
Re: too low?
#38 |
Re: too low?
yeah rust free is awesome. i have never seen anything more than surface rust on any suspension part
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() |
#39 |
LAIDOUT
Re: too low?
Maybe the stock LCAs needed new ball joints and/or bushings and the mechanic thought he was doing you a favor installing those stepped LCAs that he had laying around.
