Old 03-31-2008, 02:23 AM   #1
Down south truckin
Down south truckin's Avatar
More shifter talk and questions 4 speed 4x4
A few days ago I bought a transfer case shifter from a board member without a picture and when I opened the box I was suprised to find that the shifter was bent the wrong way or so I thought.I've often wondered what would happen in this situation on a 69-70 4x4 with the 205 transfer case the shifter is offset more than the 71-72s so that the shifter comes through the hump in the middle instead of offset to the passenger side like the 71-72s but I wondered what if it was a 4 speed truck then when you shifted back into 2nd or 4th you might hit the transfer case shifter.I had heard that only the automatics in 69-70 came with the 205s and the 4 speeds came with the muncies or dana or rockwell whatever they were called but this shifter makes me believe that some 4 speeds came with the 205.this shifter doesn't bend back like all the others instead it bends side ways towards the driver,as far as I can tell it hasn't been heated and bent because it isn"t bent in both directions back and over ,just over and I doubt that someone coulddd get it straightened out perfect then bend it sideways. These pictures compare the 69-70 shifter to the 71-72 as well as the sideways bent one to the regular one. please let me know if any body has and info to back this up or prove otherwise thanks Mike
Down south truckin is offline   Reply With Quote
Old 03-31-2008, 02:26 AM   #2
Down south truckin
Re: More shifter talk and questions 4 speed 4x4
I sent a P/M to the board member I bought it from but havn"t heard back from him maybe he will give some inputon this thread, has anybody ever seen a shifter like this one???
Old 03-31-2008, 03:31 AM   #3
JimKshortstep4x4
My son's 70 4x4 came with a SM 465 four speed and the NP 205. He is the second owner and the truck was bought that way by the original owner.
It has the transfer case shifter under the transmission shift lever and to the left side of the hump. The shift lever bolts up to the transfer case just like the 71-72's but the bends put the knob close to the driver. I can take a pic and post if you like.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-31-2008, 03:34 AM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I have 2 1970 4x4s with 4 speeds and 205 transfer cases. Both have the T case shifter that bends toward the driver like the one you have.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-31-2008, 03:54 AM   #5
muscletrucks
muscletrucks's Avatar
Check this shifter out. http://www.offroaddesign.com/catalog...seshifters.htm
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 03-31-2008, 04:41 AM   #6
sandking
.....I am working on it.....
sandking's Avatar
The shifter was from a '72 Blazer with a 4-speed SM465 and a NP205 x-fer case. Who knows what the PO's changed before I got it. If it does not work for you, let me know. I may have some pics of the inside........standby.......
sandking is offline   Reply With Quote
Old 03-31-2008, 04:51 AM   #7
sandking
sandking's Avatar
Here are a few before I started to tear things apart, but no close-ups....
Old 03-31-2008, 05:02 AM   #8
muscletrucks
dude
1943 Farmall M
Old 04-01-2008, 04:37 AM   #9
dinotruck68
dinotruck68's Avatar
i saw a shifter like the one in the blazer but it was in a 72 2wheel drive.....i dont know what the heck its doin there,, its an automatic???
dinotruck68 is offline   Reply With Quote
