Homemade C-Notch ?s
I have a 90 Silverado that I want to do a 4/6 drop on. I have the stuff to do the front 4". To save some cash and because I have the tools to do it how hard is to make my own C-Notch. If I use the steel pipe cut in half what wall thickness do I need, and will I need to box the frame above the axles. Is the steel pipe method better or should I make the notch more squared off and build it out of pieces of steel plate.
I'm not wanting a bridge notch, just something similar to the bolt in Bell Tech notch but not costing a lot of money. Any help is appreciated.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
Re: Homemade C-Notch ?s
i would say 1/4 inch thickness, and yes it would be good to box the frame
to answer your other question, a seamless tube would be stronger.
off the subject here for a minute ... you gonna be at Barber's for the AMA even next month? If so give me a yell by way of PM.
Pipe or tube will work fine, I used a piece of 4x6 tube and cut the bottom out. I plated the outside of the frame and boxed the inside frame with 3/16inch plate. I used the tube becuase it is what I had but round pipe will work just as well. Nothing wrong with saving a few bucks either. Greg
Thanks for the info guys.
Shane PM sent.
If you will,, would you post pictures as you go? I'm building the same stuff right now,but on an 85. I guess that I should save pictures too as I go. Your pictures will help as we all build. One more thing,,If I do take pics,, is it appropriate to post here (in your simular build) or start a new thread ?
Current rides ![]() |
I will try to get pics as I go. I'm still not sure wich way I'm going on this. I sent an email to Tim Christian about a bolt in notch by itself. I really dont want to buy a kit. I plan on buying after market axle saddles and making my own shock extenders. I have already spent what my wife considers to much for the front drop, and I havent even bought the shocks yet.
I have a piece of 4x6 rectangle tube. If I cut it to 2x6 will that be wide enough and deep enough for my notch.
Happy to be here
![]() Join Date: Mar 2000
If your only looking for a small notch then pipe or tubing will work just fine. You definitely want to box the inside for added strength.
I've done it both ways and can tell you that the bolt-in type is much more advantageous once all the time is considered. It seems like a lot of dough up front, but it really isn't once you consider your time and the materials used.
The quote I got was a little over 300 dollars for a 6" flip kit. C-notch axle saddles and shock extenders.
Saturday I finally got the settlement check for my totaled S-10. I went straight to the bank then SECO Performance and picked up my 2" dropped spindles and 2" dropped springs. Total price $347.75. Got in the van to go home and wife asks me how much did I spend. I still have not heard the end of it. I took her clothes shopping, and got landscape stuff for the house. She is still P.O.d. And tonight the starter quit. So if I spend any more on the truck I'm a dead man. I have to find an inexspensive way to lower the back, I figure I got a welder and some cutting implements it shouldnt be that hard. I hope she doesnt find out I want some grey center 15x7 and 15x8 American Racing Tourqe Thrust IIs, and I plan on using the rebate check for those. Its just money I get a paycheck every 2 weeks, whats the big deal.
